JBM
Joined: 12 May 2004 Posts: 54 Location: edinburgh, Scotland
Problems detecting / programming PIC18F67J10 |
Posted: Wed Feb 08, 2006 1:09 pm |
I've made up a board with an 18F67J10 on it, but the ICD doesn't recognise it.
The conections are
B7 -> B7 programming pin
B6 -> B6 programming PIN
0V -> 0V
Mclr -> MCLR pin
My target Vdd is running at 3.3V, not 5V.
Additionally, the ENVREG is pulled up to Vdd, and Vcap is connected to ground through a 10uF cap.
I'm using a ICD-U40 (firmware version 1.39) and V2.48 of the windows software.
The message I (usually) get is:
Unknown PIC18 device, ID: 0101 if this is a valid id, then makre sure the algorithm inside chipedit is set correctly.
Obviously i'm missing something - any ideas people?
thanks
-JBM |
JBM
Posted: Wed Feb 08, 2006 2:33 pm |
True, it isn't there, however going into the advanced menu , and clicking on the devices drop-down box it is in there.
But, that list does look remarkably similar to the "supported devices" list.
oop.
OK, supposing the ICD-U40 isn't going to make it happen, do i need an ICD2 or somesuch?
P.S. Thanks for the quick reply PCM Programmer - i'm still at the bench tearing y hair out!
P.P.S.
That was the problem - PCM , you really are too good. I pulled ENVREG high, and put in an 18LF6720. It'll do for now, but i've had to drop my clock freguency from 40 to 20MHz. |
Posted: Wed Feb 08, 2006 4:20 pm |
My advice is to contact CCS support and verify that the chip is really
supported. |
