microchipc bootloader question
Latech
PostPosted: Tue Feb 07, 2006 3:07 pm     Reply with quote
#include <16F877.h>
#fuses NOWDT,NOPROTECT,HS
#use delay(clock = 20000000)
#use rs232(baud=19200, xmit=PIN_c6,rcv=PIN_c7,errors)
#org 0x1F00, 0x1FFF void loader16F876(void) {}
   while (true)
   printf("hello\n\r");
I get an error of invalid ORG range, this code works on my older compiler. Whats the problem?
Nick[/code]
PostPosted: Tue Feb 07, 2006 3:14 pm     Reply with quote
What's your compiler version? It compiles OK with PCM vs. 3.242.
Also, are you using a LVP programmer ? If not, you need to add NOLVP
to your #fuses statement.
PostPosted: Tue Feb 07, 2006 4:18 pm     Reply with quote
Are you using an In Circuit Debugger like the ICD2? These device are using a small memory area at the end of RAM, this might be conflicting with your #org.
