keypad input for analog signal
crushneck
PostPosted: Sun Feb 05, 2006 9:43 pm     Reply with quote
I need help on my project...i need to make it like when i press number 1 of my keypad, a current analog input shown in LCD...so also when i press 2,a voltage analog input shown in LCD..i try to edit the code...but the output is wrong...can sumone take a look at my source code...maybe u can help by editing it...thanks
#include <18F452.h>
#device adc=10
#use rs232(baud=9600,parity=N,xmit=PIN_C6,rcv=PIN_C7,ERRORS)  //pin25=c6, pin26=c7
#include <lCD420.c>
#include <kbd.c>
void main() {
char k;
int16 result;
float adcresult;
port_b_pullups(TRUE);
kbd_init();
setup_adc_ports(AN0);
setup_adc(ADC_CLOCK_DIV_8);
set_adc_channel(0);
while (TRUE) {
      result = read_adc();
   adcresult = (float)result * (5.0/1024.0);// a to d is 10 bits. 2^10=1024
      k=kbd_getc();
      if(k!=0)
         if(k=='1')//when 1 is pressed, current input shown
          lcd_gotoxy(1,2);
         printf(lcd_putc, "\n\r ADC (I): %5.2fmA\r\n", adcresult);
         if(k=='2')//when 2 is pressed, voltage input shown
         lcd_gotoxy(1,3);
         printf(lcd_putc, "\n\rADC (V):%5.3fV\r\n", adcresult);
         lcd_putc(k);
rwyoung
PostPosted: Tue Feb 07, 2006 1:42 pm     Reply with quote
Some questions:
1) Why are you sending newline ('\n') and carriage-return ('\r') characters when you just told the LCD exactly where you wanted to start printing with the gotoxy() function?
2) You have a multi-line comment block started on the line with k=kbd_getc() and ending just before the else statement. I'm supprised the compiler isn't throwing an error but if it isn't then all you are doing is puting the contents of variable k on the lcd at the current position. k could hold any value from 0 to FF because you haven't initialized it or assigned a value. Did you mean to coment out that block of code?
Rob Young
crushneck
PostPosted: Tue Feb 07, 2006 7:37 pm     Reply with quote
Sorry i actually dun understand the characters. im new to this programming. can u explain more about the characters? i noe theres a help in PIC C compiler but i still dont get it.
yes. actually i want u to comment this part. i jus want to make it like when number 1 of my keypad, a current analog input shown in LCD. so also when i press 2,a voltage analog input shown in LCD.
crushneck
PostPosted: Thu Feb 09, 2006 2:04 am     Reply with quote
anyhelp anyone?
