PIC18F8680/External Flash Memory doubt
pasini
PostPosted: Mon Feb 06, 2006 1:24 pm     Reply with quote
I have a PIC18F8680, running at 20MHz/5V, connected to an external AM29F800B Flash memory. I have 2 74HC373 between memory and MCU, in a 8051-like way.
The code runs for others tasks but I see no memory signals on the scope.
MPLAB 7.3 PCB/PCM/PCH 4.241
Does anybody has a sample routine I can see or any suggestions ?
Thanks in advance.
Pasini
My code is:
#include "18f8680.h"
#device *=16 ADC=10
#fuses HS,NOWDT,NOPUT,NOPROTECT,NOBROWNOUT,NOLVP,NOCPD,NOWRT,EMCU,WAIT
#use FAST_IO (C)
#case
void WriteExtFlash(void)
   int32 i;
   int8 value;
   value= 0xAB;
   for(i=0;i<=9;i++)
   {   value = i;
      write_external_memory(i, &value, 1);
      delay_ms(7);
void ReadExtFlash(void)
   char buffer[10];
   read_external_memory(0, buffer, 10);
   delay_ms(1);
void TesteMemoria(void)
   char buffer[100];
   {   DesligaMem();
      LigaMem();
      WriteExtFlash();
      ReadExtFlash();
   // setup PWM
   setup_ccp1 (CCP_OFF); // disable PWM hardware
   setup_ccp2 (CCP_OFF); // disable PWM hardware
   // setup ADC
   setup_adc_ports(AN0_TO_AN1|VSS_VDD);
   setup_adc(ADC_CLOCK_DIV_32);
   // setup counters
    setup_counters(RTCC_INTERNAL,RTCC_DIV_2);
    // setup external memory
    LigaMem();    // is equal to output_high(RESET_MEM)
    setup_external_memory(EXTMEM_WORD_WRITE|EXTMEM_WAIT_0);
    // setup interrupts
   set_tris_a(0b00010011);
   set_tris_g(0b00000000);
   set_tris_c(0b11000011);
   set_tris_f(0b00000000);
   set_tris_j(0b00000000);
   // definis iniciais
   DesligaBuzzer();
   LigaBckLight();
   LigaContraste();
   LigaMCU();
   LigaMem();
                TesteMemoria();
PostPosted: Tue Feb 07, 2006 2:11 am     Reply with quote
The data sheet for the 18F8680 has a chart on page 55 (in the Acrobat
reader) which shows that in Extended Microcontroller mode, the external
memory starts at address 0x10000.
If you look in the CCS driver file AT29C1024.C, they add the offset
within the external memory chip to the base address of the external
memory, in order to create the full correct address. You need to do
this too. Example:
#define EXT_MEM_BASE_ADDR  0x10000
write_external_memory(EXT_MEM_BASE_ADDR + i, &value, 1);
And also for the read:
read_external_memory(EXT_MEM_BASE_ADDR, buffer, 10);
I haven't used external memory before, so I don't know for sure
if this is the complete answer to get it running, but it will certainly help.
