Asynchronous Serial Routine
cfernandez
PostPosted: Sun Feb 05, 2006 9:48 am     Reply with quote
I have some problems with the software uart and I want to use other routine that CCS, somebody write serial routine for no UART ports ?.
Is possible that post this?
Thank you very much!!
rwyoung
PostPosted: Sun Feb 05, 2006 7:32 pm     Reply with quote
Go look at http://www.piclist.com/techref/microchip/rs232.htm. Probably all in assembly but from that you can either work backwards or re-code as in-line.
Also http://www.pic101.com/mcgahee/ is well worth a visit. Fr. Tom McGahee has a very well documented set of RS232 functions.
Rob Young
Freddie
PostPosted: Fri Feb 10, 2006 5:10 pm     Reply with quote
In CCS you can use any pin as a serial port, regardless if that pin has a hardware UART port on it. It works great. I use it all the time..
Look in the manual, but you want to do something like this:
#define ToPC                   PIN_C6   //your pins here
#define FromPC                   PIN_C7  //your pins here
#use rs232(BAUD=9600, XMIT=ToPC, RCV=FromPC, STREAM=serialPC)
printf(serialPC,"TestBoxFound\r\n");
PostPosted: Fri Feb 10, 2006 5:16 pm     Reply with quote
He doesn't want to use the CCS library code:
PostPosted: Sat Feb 11, 2006 10:45 am     Reply with quote
Though it would be interesting to know 'why not' The CCS code, except for a few problems on specific chips/versions, is pretty good.
Freddie
PostPosted: Sat Feb 11, 2006 1:46 pm     Reply with quote
Oh, I see.
If you don't want to use the built-in CCS serial routines, and have not found anything else yet, you could use Peter Anderson's serial routines.
You have to purchase his PIC Routine Library (wich is excellent BTW) at:
http://www.phanderson.com/PIC/PICC/pic_c_routines.html
Here is a sample program that uses his routines:
http://www.phanderson.com/PIC/PICC/CCS_PCM/lcd_f84.html
Hope this help. Very Happy
