DS18S20 being stubborn
barkerben
PostPosted: Sat Feb 04, 2006 3:49 pm     Reply with quote
Hello...
I've been trying all day to interface a DS18S20 temperature sensor to a PIC18F452. I have done my best to follow the steos in the data sheet to the letter but always read -1 degrees. The fact that I'm not shivering suggests otherwise :-)
The probe can run in parasitic mode but for now I'm running it of the board supply for simplicity - no charging during temperature conversion etc.
I don't know if anyone else has used this before. There were some other posts, but I started my own code becuse, looking at the datasheet, and with the help of the CCS example code, it looked straighforward...
Any thoughts?
#include <18F452.h>
#fuses HS,NOPROTECT,NOLVP
#define PC_TX PIN_D2
#use rs232(baud=9600, xmit=PC_TX,stream=PC)   //TX line to level converter and PC
#include <string.h>
#include <stdlib.h>
#define TOUCH_PIN  PIN_D1
void touch_write_byte(BYTE);
BYTE touch_read_byte();
void main() {
   signed int16 temperature;         //Signed 16 bit word to store temperature in
   #BYTE high_byte = temperature
   #BYTE low_byte =  temperature + 1
   while (TRUE) {
        output_low(TOUCH_PIN);
        delay_us(500);                 //Master issues reset pulse, then releases line
        output_float(TOUCH_PIN);
        touch_write_byte(0xCC);        //We only have one device, so use 'skiprom' command for simlicity - all (one) devices are addressed
        touch_write_byte (0x44);       //Master issues command to start temperature conversion
        delay_ms(1000);                //Wait for temp. conversion (750ms max from data sheet)
        touch_write_byte(0xCC);        //Address all probes (we only have 1)
        touch_write_byte (0xBE);        //Ask it to send us scratchpad register
        high_byte = touch_read_byte(); //There are 9 bytes sent, but for now we only nee the first two - the basic temperature
        low_byte = touch_read_byte();  //So issue a reset after the second byte has been read
        fprintf (PC,"\r\nTemperature: %Ld C",temperature);
        delay_ms (1000);
BYTE touch_read_byte() {
   BYTE i,data;
//see page 13 0f data sheet
   for(i=1;i<=8;++i) {
     output_low(TOUCH_PIN);         //Start of read time slot. First, hold line low for 5us (min 1)
     delay_us(5);
     output_float(TOUCH_PIN);       //Now release the line so that the slave can send. Send will last for 15us from falling edge of time slot
     shift_right(&data,1,input(TOUCH_PIN)); //Read a 1 or 0 from the line.
     delay_us(20); //Hold for 20us to ensure master has read bit and to provide recovery time between slots
     //loop around 8 times to get an entire byte
   return(data);
void touch_write_byte(BYTE data) {
   BYTE i;
  //see page 12 0f data sheet
   for(i=1;i<=8;++i) {  //Loop around 8 times to read an entire byte
     output_low(TOUCH_PIN);    //Start of write time slot
     delay_us(10);
     output_float(TOUCH_PIN);  //release within 15us to start slot
     if(shift_right(&data,1,0)) {   //we shift a bit out of the data byte, ad see if it is a 1 or a 0
       output_high(TOUCH_PIN);      //if it is a 1, then we send the pin high
       delay_us(60);                //and leave it high for 60us
     } else {
       output_low(TOUCH_PIN);       //else, it must be a 0, so we senf the pin low
       delay_us(60);                //and again leave it for 60us
     output_float(TOUCH_PIN);       //release line
     delay_us(50);                  //recovery time
PostPosted: Sun Feb 05, 2006 2:01 pm     Reply with quote
I haven't looked at the rest of your code, but here is 1 serious bug:
Change it to
   #BYTE high_byte = &temperature
   #BYTE low_byte =  &temperature + 1
