steph Guest
icd-u40 communication problem PLEASE HELP |
Posted: Tue Dec 02, 2003 7:42 pm |
Hi
I just received my ICD U40.
i connect it to me computer. Win XP
The computer detect my ICD.
I installed the driver.
When i communicate for first time, the software
ask me to update Firmware. i did it.
MY problem: when i try to communicate with the icd,
the icd reponse:
COULD NOT CONNECT: CANNOT GET FIRMWARE VERSION:
UNIT IN WRONG MODE OR COMMAND NOT SUPPORTED.
Could you help me , i do not find any detail about this problem.
How can I change the mode or reload firmware if the first window
does not appear anymore?
Please
Stephane |
ajt
Posted: Tue Dec 02, 2003 11:13 pm |
When I first got my ICD-U going I had a few problems and ended up unplugging the USB connection, waiting about 10 seconds and reconnecting it. Then the ICD.exe program as well as the PCWH IDE worked fine. Also make sure you select ICD-U and not ICD-S _________________ Al Testani |
steph Guest
Posted: Wed Dec 03, 2003 5:11 am |
I take a look on connection window.
I use ICD-U and the baudrate is 250000.
sometimes a change the speed for 9600baud.
But same problem.
thanks
Steph |
Posted: Wed Dec 03, 2003 6:36 pm |
This exact thing happened to me and I was informed by CCS that I would have to return the unit. |
steph Guest
Posted: Wed Dec 03, 2003 6:46 pm |
Could you tell me how long does it take? |
Guest Guest
Re: icd-u40 communication problem PLEASE HELP |
Posted: Thu Feb 02, 2006 9:20 pm |
Hi!
I've had the same problem (ICD-U40), to resolve the issue I've re-installed ICD software from the CD!!!
This work but don't know why!!!!!!
Good luck!
steph wrote: | Hi
the icd reponse:
Please
Stephane |
