PIC18F2410 write_eeprom write_program_eeprom Compile Problem
hoppenfeld
PostPosted: Wed Feb 01, 2006 2:55 pm     Reply with quote
We recently upgraded a PIC16F88 to a PIC18F2410. For the most part the upgrade has gone well except for writing to the PIC EEPROM. Previously we used the write_eeprom however this no longer compiles. We then tried the write_program_eeprom and write_program_memory functions with the appropriate parameters but get the same compile error:
Undefined identifier write_eeprom
Undefined identifier write_program_eeprom
Undefined identifier write_program_memory
On the other side the switch from read_eeprom to read_program_eeprom compiles with no problems.
Any insight would be greatly appreciated.
Thank you,
Robert
PostPosted: Wed Feb 01, 2006 3:01 pm     Reply with quote
According to the 18F2410 data sheet:
1. There is no mention of Data EEPROM in this PIC.
2. This PIC can't write to its program memory.
From the data sheet:
In PIC18F2X1X/4X1X devices, the program memory is
implemented as read-only Flash memory.
18F2410 data sheet:
http://ww1.microchip.com/downloads/en/DeviceDoc/39636a.pdf
hoppenfeld
PostPosted: Wed Feb 01, 2006 3:07 pm     Reply with quote
You should be able to write to flash memory using the write_program_memory command. Correct?
PostPosted: Wed Feb 01, 2006 3:19 pm     Reply with quote
From the 18F2410 data sheet:
From the Table of Contents of the 18F2410 data sheet in the
Acrobat Reader:
6.0  Flash Program Memory
  +  6.1  Table Reads
  +  6.2  Control Registers
  +  6.3  Reading the Flash Program Memory
hoppenfeld
PostPosted: Wed Feb 01, 2006 5:23 pm     Reply with quote
Thanks. We are replacing the part with a PIC18F2420.
