carm Guest
SPI: żIt´s possible send 16 CLK´s on a SPI instruction? |
Posted: Tue Jan 31, 2006 9:32 am |
I have a problem.
I have an ADC wich need 16 bit instructions (LTC1859).
If i use SPI instructions, i only can send 8 bits with CLK´s, and if i repeat the instruction with the correct code, appear a "dead time" between clk´s.
żIt´s possible make 2 byte intructions with SPI without the "dead time"?
Here is the code:
#include <16F873A.h>
#device adc=10
#device ICD=TRUE
#include <stdio.h>
#fuses XT,NOWDT,PUT,NOPROTECT,NOBROWNOUT,NOLVP
#use rs232(baud=9600,xmit=pin_c6,rcv=pin_c7)
long conv=0,convh,convl;
void main (void){
setup_adc(adc_off);
setup_adc_ports(no_analogs); //configuro puerto A como digital
set_tris_a(0xFF);
set_tris_b(0xFF);
set_tris_c(0x92); //configuro puertos
setup_spi(spi_master|spi_l_to_h|spi_clk_div_4); //configuro modo SPI
output_low(pin_c2); //inicializo RD nivel bajo
output_low(pin_c0); //inicializo CONVST a nivel bajo
while(TRUE){
spi_write(0x84); //configuration to AD
spi_write(0x00); //send 0x00
output_high(pin_c0);
while (!input(pin_c1)){}
conv=spi_read(0); //
output_low(pin_c0);
printf("\n\r%ld",conv);
}//cierro while
}//cierro main |
libor
Posted: Tue Jan 31, 2006 11:06 am |
In synchronous data transfers (those with a CLK line) like SPI, there must be no problem having a 'dead time' anywhere in the data stream, that is the reason the CLK line is implemented for. |
