		| Author | Message |
		| guest Guest
				| cascading eeprom!!! |
				|  Posted: Tue Jan 31, 2006 4:08 am |   |
				| Hi everyone,
 I am using the 24lc256's driver file (24256.c) as a driver to my Atmel's 24cxx eeprom(32kbytes). I was wondering if there is any way to cascade two or more such eeproms to get larger capacity (of 64kbytes or more ).
 If there is a way to cascade then what hardware connections are needed and how each cascaded memory is to be addressed in the code.
 I have a compiler version ver 3.203.
 Regards
 ft
		| Humberto
				|  Posted: Tue Jan 31, 2006 8:31 am |   |
				| It is very straightforward to connect multiple devices. Except if you are using the MOSP package, up to 8 devices can be connected sharing the same I2C bus + 3 address lines
 (A0, A1, A2) to select them. The datasheet get you this info.
 Humberto
		| treitmey
				|  Posted: Tue Jan 31, 2006 9:23 am |   |
				| And I wrote a driver for the RAMTRON FRAM FM24C256 http://www.ccsinfo.com/forum/viewtopic.php?t=24099
 That shows the memory as a flat address space.
 note that FM24C256 and your chip are not the same...
 Fram is much faster.
 But this will give you ideas on how to handle a multi-write that spans
 2 chips.
 ie you have to do a stop at last address.  Then a start, addr of next chip
