Printing Binary Representation.....
PostPosted: Sun Jan 29, 2006 9:00 pm     Reply with quote
I have a status byte that is read from an external piece of hardware and I'd like to print out the binary representation of the byte for clarity during troubleshooting. Can this be done directly, or will I have to test each bit individually and then display them?
Ian
PostPosted: Sun Jan 29, 2006 9:44 pm     Reply with quote
The answer is in the archives.
http://www.ccsinfo.com/forum/viewtopic.php?t=18826
treitmey
Binary print
PostPosted: Mon Jan 30, 2006 10:53 am     Reply with quote
This is how I print binary. This could be shortened/cleaned up.
#include <16F877a.h>
#device *=16
#fuses hs,nowdt,nolvp,protect,put,brownout
#use rs232(baud=19200,xmit=PIN_B4,INVERT,stream=DEBUG)
#case
#zero_ram
void bin_putc( char c);
//======================= Main ==============================
  int8 data=180;//180=0xB4=1011 0100
  printf(bin_putc,"This is a test %lX\n\r",data);
//======================= print binary nibbles from hex ============================//
void bin_putc( char c) {
//converts hex to bin
//printf(bin_putc,"%lX\n\r",data);
switch (c) {
      case '0'   :
          fprintf(DEBUG,"0000 ");
      case '1'   :
          fprintf(DEBUG,"0001 ");
      case '2'   :
          fprintf(DEBUG,"0010 ");
      case '3'   :
          fprintf(DEBUG,"0011 ");
      case '4'   :
          fprintf(DEBUG,"0100 ");
      case '5'   :
          fprintf(DEBUG,"0101 ");
      case '6'   :
          fprintf(DEBUG,"0110 ");
      case '7'   :
          fprintf(DEBUG,"0111 ");
      case '8'   :
          fprintf(DEBUG,"1000 ");
      case '9'   :
          fprintf(DEBUG,"1001 ");
      case 'A' || 'a'   :
          fprintf(DEBUG,"1010 ");
      case 'B' || 'b'     :
          fprintf(DEBUG,"1011 ");
      case 'C' || 'c'    :
          fprintf(DEBUG,"1100 ");
      case 'D' || 'd'     :
          fprintf(DEBUG,"1101 ");
      case 'E' || 'e'     :
          fprintf(DEBUG,"1110 ");
      case 'F' || 'f'     :
          fprintf(DEBUG,"1111 ");
      default     :
         fprintf(DEBUG,"%C",c);
Humberto
PostPosted: Mon Jan 30, 2006 2:29 pm     Reply with quote
Following is PCM Programmer code slightly optimized.
void display_binary(char c)
char i;
   i = 8;
   putc('0');
   putc('b');
   do
       if( c & 0x80 )
         { putc('1'); }
         { putc('0'); }
       c <<= 1;  i--;
     } while(i);
Short, fast and elegant.
Humberto
