ds1302 and pic16f877 problem
umity
PostPosted: Mon Jan 30, 2006 5:01 am     Reply with quote
i want to use ds1302 with 16f877. i have a problem. I saw on Lcd all times
165/165/165
165:165:165
it doesn't change
my code is here, ı couldnt find the problem.
#include "C:\Program Files\PICC\rrr.h"
#include <math.h>
#include <stdlib.h>
#include<ds1302.c>
#include<LCD.c>
int n=0;
int day,mth,year,dow;
int hour,min,sec;
char address;
char data;
setup_adc_ports(NO_ANALOGS);
setup_adc(ADC_OFF);
setup_psp(PSP_DISABLED);
setup_timer_1(T1_DISABLED);
rtc_init();
lcd_init();
rtc_set_datetime(11,11,05,11,11,11);
while (1) {
lcd_putc('\f');
rtc_get_date( day, mth, year, dow);
rtc_get_time( hour, min, sec );
printf(lcd_putc,"%2u/%2u/%2u\n%2u:%2u:%2u",mth,day,year,hour,min,sec);
delay_ms(250);
PostPosted: Wed Feb 01, 2006 2:29 pm     Reply with quote
165/165/165
165:165:165
When an RTC chip gives you these types of values, it's typically
because you forgot to connect a 3v lithium battery to the Vbat pin.
See the following thread. The first person has the battery problem
and the 2nd person has a crystal problem. Check your board
for these problems:
http://www.ccsinfo.com/forum/viewtopic.php?t=19926
