I am working on a PIC18F2410 and the following odd action happens in my code. The code will reset the processor on the delay_cycles function. I have tried moving the code, walking through with the ICD-U40, and changing the surrounding code.
When I step through the code I get the following error:
"Invalid Clock Value from the debugger. Debugging may not have been enabled."
Any help would be greatly appreciated.
Posted: Fri Jan 27, 2006 4:34 pm
Is this entirely a debugger issue ? Does it still crash when the code
is programmed into the PIC so that the program runs in Stand-alone
mode ?
Error may not be code
Posted: Fri Jan 27, 2006 4:48 pm
The crash happens all of the time. However the EE now says that it may be a trace problem with the board. We are going to try a different board. Wish he would have told me that before I posted for help. Thank you for all of the effort. I appreciate it.
Humberto
Posted: Sun Jan 29, 2006 7:22 am
1) LED_OFF; // is th¡s to be sure that it should be OFF ?
LED_ON;
2) Do you have INT_EXT1 enabled for any reason ?
If so, did you coded the handler ?
