MCP23S08 doesn't work |
Posted: Fri Jan 27, 2006 12:50 pm |
Does anyone have a working code example for the MCP23S08 GPIO expander? I can't seem to find what is wrong with the code below. The expander chip never replies to anything sent to it. It's SDO pin stays low all the time. This device is like the MCP23S17 but it only has one I/O port.
//* write_gpio(int8 address, int8 data) subroutine ******************************
// address = register address
// data = data to place in register
// Initializes GPIO chip
void write_gpio(int8 address, int8 data) {
output_low(GPIO_CS);
spi_write(0x40); // Hardware address and R/W bit (bit 6 always on)
spi_write(address); // Register address
spi_write(data); // Data to send
output_high(GPIO_CS);
//* read_gpio(int8 address) function *******************************************
// Returns: data from register
// Reads a value from the MCP23S08 GPIO expander
int8 read_gpio(int8 address) {
int8 data=0;
spi_write(0x41); // Hardware address and R/W bit (bit 6 always on)
data=spi_read(0); // Read data in
return(data);
Posted: Fri Jan 27, 2006 1:19 pm |
Post your setup_spi() statement. Also post your PIC type, #fuses
statement, and #use delay() statement. |
Posted: Fri Jan 27, 2006 1:23 pm |
Here is the setup_spi statement and the first few lines of the source code.
#include "18f452.h"
#device ADC=10
#fuses HS, NOPUT, NOWDT, NOPROTECT, NOLVP, CCP2C1, NODEBUG, NOBROWNOUT
#use delay (clock=3686400)
setup_spi(SPI_MASTER | SPI_L_TO_H | SPI_CLK_DIV_64);
I've played with the SPI clock quite a bit trying different values. Not that it should matter though since the MCP23S08 can run up to 10MHz and my crystal is only good for 3.6864MHz. |
Posted: Fri Jan 27, 2006 1:47 pm |
Based on the Figure 2-5 (pg. 26) of the MCP23S08 data sheet, "SPI Input
Timing", it looks like data should be clocked out of the PIC on the negative edge of SCLK. This means you need to change the edge
parameter of setup_spi() to:
That parameter controls which edge of SCLK is used to clock the data
out of the PIC. |
Posted: Fri Jan 27, 2006 3:13 pm |
Thanks. I needed SPI_XMIT_L_TO_H as well, but you certainly got me going in the right direction. I'll post up what I have in the code library when I get this completed as a reference for anyone else who has problem(s) with this family of chips. |
Humberto
Posted: Sun Jan 29, 2006 6:21 am |
The MCP23S08 has 10 Configuration and Control Registers that determine its behaviour.
You didn't show us how it was setted. To help you we need a complete and compilable
example code that demostrate the problem.
Humberto |
lfander Guest
Posted: Thu Jul 16, 2009 10:02 am |
What does this comment mean ???
I've tried using this expander to light LEDs. Seven pins will sink current, but bit 6 will never will. Any ideas |
Posted: Thu Jul 16, 2009 1:28 pm |
spi_write(0x40); // Hardware address and R/W bit (bit 6 always on) |
When you're trying to understand a driver, it's essential to look at the
chip's data sheet. Download the mcp23s08 data sheet from this page:
http://www.microchip.com/wwwproducts/Devices.aspx?dDocName=en021817#1
Look at this bit diagram on page 8 of the mcp23s08 data sheet:
Quote: | FIGURE 1-3: SPI CONTROL BYTE FORMAT |
It explains the comment in the code. |
lfander Guest
Posted: Thu Jul 16, 2009 2:14 pm |
I understand drivers and I did look at the data sheet first. Bit 6 is always high implies a hardware condition, not a "1" in the code sent to the device, thats why I asked. The pin controlled by bit 6 (GP6) is unresponsive when driven low as per Microchips app notes and data sheets, while the other pins do respond. That was my question. |
Posted: Thu Jul 16, 2009 2:18 pm |
1. Post a short, compilable test program that shows the problem.
2. Post your compiler version.
3. Post a description of the external circuits connected to the GP6 pin. |
