PICDEM FS USB bootloader CCS
tretec
PostPosted: Wed Jan 25, 2006 4:19 am     Reply with quote
Hi everyone,
I'm trying to use the CCS USB example code on the Microchip PICDEM FS USB board. I need to relocate the USB interrupt service routine because the first parte of the memory is occupied by the bootloader.
Does anyone know how if it is possible?
thanks in advance
Bruno
treitmey
PostPosted: Wed Jan 25, 2006 9:14 am     Reply with quote
Lookup #build in the help file.
Also the bootloader example code shows how to use this.
tretec
error
PostPosted: Thu Jan 26, 2006 3:21 am     Reply with quote
Yeah, I've tried in this way but there is some code in CCS USB code that points at a determined position, so of I try to reserve some space fore the bootloader I get this message error:
Error[300] C:\Utenti\Corra\Progetti\USB_BOARD\TEST_CCS\boot_ccs.c 74 : More info: Segment at 00000-007FE (0000 used) Priv
Error[300] C:\Utenti\Corra\Progetti\USB_BOARD\TEST_CCS\boot_ccs.c 74 : More info: Segment at 00800-00806 (0004 used) Priv
Error[300] C:\Utenti\Corra\Progetti\USB_BOARD\TEST_CCS\boot_ccs.c 74 : More info: Segment at 00808-07FFE (0000 used)
Error[300] C:\Utenti\Corra\Progetti\USB_BOARD\TEST_CCS\boot_ccs.c 74 : More info: Attempted to create: 00806-0089C for ISR
Error[126] C:\Utenti\Corra\Progetti\USB_BOARD\TEST_CCS\boot_ccs.c 74 : Invalid ORG range
1 Errors, 0 Warnings.
beginner
PostPosted: Thu Jan 26, 2006 7:58 am     Reply with quote
Hi!
You can try this :
#build(reset=0x800, interrupt=0x808)
#org 0x000, 0x7ff { }
Regards
tretec
PostPosted: Fri Jan 27, 2006 1:55 am     Reply with quote
Thanks a lot!!!
It works fine!!
GREAT!! Very Happy
But now I've got a new question:
I had done a way like this. My old code was
#build(reset=0x800)
#build(interrupt=0x808)
#org 0x0000,0x07ff {} //bootloader()
but it didn't work..
Does anyone know why?
Congratulations for the forum, it's very useful and congratulations and tnx to the users!!
Regards Bruno
