On Board A to D Conversion?
arrow
PostPosted: Wed Jan 25, 2006 4:38 am     Reply with quote
Hi
I have been doing A to D conversion on board the PIC16F873. This is the code that worked pretty well for me:
   set_adc_channel( 0 );
   delay_us(40);
   Ch0 = Read_ADC();
Can someone please tell me how many useconds this conversion takes, and is the 40us delay necessary?
Thank you in advance.
a.
MikeValencia
View user's profile Send private message Send e-mail Yahoo Messenger
PostPosted: Wed Jan 25, 2006 7:06 am     Reply with quote
I also put a delay after i set the a/d channel, sometimes even for 1 ms. This is because i have not figured out all those cryptic formulas in the datasheet!
Anyhow, once you do have the a/d channel set, try not to set it again, especially if you won't be invoking other a/d channels. This way, you can avoid the lengthy delays just to let it settle.
SherpaDoug
PostPosted: Wed Jan 25, 2006 8:23 am     Reply with quote
That 40us delay only applies if you change A/D mux channels. To understand its length you have to first understand the exponential decay of an RC circuit. Any EE book will cover it in the first few pages. Then you find the R and C values for the datasheet and see how much of the decay curve you need to give the time required.
I'm afraid there is no shortcut to understanding these fundamental analog principles.
arrow
PostPosted: Thu Jan 26, 2006 3:24 am     Reply with quote
Hi
Thank you guys.
So the delay_us(40)
is actually for the set_adc_channel( 0 );
I will try this right now.
Regards
a.
