Data transfer and protocols
Michael_B
PostPosted: Tue Jan 24, 2006 6:40 am     Reply with quote
Good day.
Can someone please explain me what to if i want to make this situation to work.
Hardware parts:
Transmiter
Reciever
Radio data transfer
Short range
Programming:
I send text data from transm. to reciever
Which data transfer protocol should i use and how to bundle this with CCS C ?
I know that this is bit "major" question and if you need additional info , please let me know...
jay miller
transfer protocall
PostPosted: Tue Jan 24, 2006 6:45 am     Reply with quote
None, until you get reliable communications working! Both hardware and software should be tested without any, just simple 8 bit transfers.
Then you can decide , based on level of security, whether you need CRC,XMODEM or 'roll your own'. The later is best as only you should be able to make sense of the data stream.
I did that 30 years ago and noone has ever been able to 'break the lock'.
specialk
PostPosted: Tue Jan 24, 2006 7:54 am     Reply with quote
Maybe try using a Laipac RF-24G Transceivers (http://www.ccsinfo.com/forum/viewtopic.php?t=25745)? From my experience, they are much more reliable than the plain old ASK 434MHz transmitter/receiver pairs.
Check out http://www.istop.com/~micro/electronics/rf.htm for an example of a serial bridge.
-special [k]
PostPosted: Tue Jan 24, 2006 9:00 am     Reply with quote
Laipac RF-24G
hmmm, nice :-) but ...
I want to get data transmition range between 0 - 5 KM and i dont want to use such high frequency. In our country 5W output is the maximal FREE output which someone can use and this should be free service ( for such range ).
Is there possibility to get tranceiver with cca 500-700 MHZ which can be used with maximal output (5W) to get the 5 KM range ? There are some free frequencys in this range.
Any suggestions ?
Please note, i want to use the lowest frequency as possible ( for such range ).
newguy
PostPosted: Tue Jan 24, 2006 10:51 am     Reply with quote
This will help you to implement and test a wireless link:
http://www.ccsinfo.com/forum/viewtopic.php?t=23953
Sorry, but I have no suggestions regarding which wireless module(s) and what frequency would suit you.
specialk
PostPosted: Tue Jan 24, 2006 11:23 am     Reply with quote
Here in the US, most of the radio bands are restricted in one way or another as well as the power of the radio signal being broadcasted. I wouldn't be able to make any suggestions for such a distance; however, amateur radio enthusiasts may have an idea as to what your options for a PIC-based wireless solution would be.
-special [k]
PostPosted: Tue Jan 24, 2006 12:02 pm     Reply with quote
Can you point me where to ask or should i wait if someone, at ccs forum, see this post ?
specialk
PostPosted: Tue Jan 24, 2006 12:52 pm     Reply with quote
I checked here http://www.electro-tech-online.com/viewforum.php?f=5 and found a link to http://www.radiometrix.co.uk/, which has a number of transmitters, receivers, and transceivers that can have 100mW broadcast power (including http://www.radiometrix.co.uk/products/bim1.htm, which has "Usable range over 10km"). Maybe check them out and look for a distributer in your area to contact.
-special [k]
PostPosted: Tue Jan 24, 2006 1:15 pm     Reply with quote
HEY MEN, YOUR THE BEST :-).
Im gonna take a look i i get back to you tomorrow !
