I have "undefined indentifier" problem when I comp
sonicdeejay
PostPosted: Tue Jan 24, 2006 3:25 am     Reply with quote
#include <18F452.h>
#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7) // Jumpers: 8 to 11, 7 to 12
void main() {
int i, value, min, max;
printf("Sampling:");
setup_port_a( ALL_ANALOG );
setup_adc( ADC_CLOCK_INTERNAL );
set_adc_channel( 0 );
do {
min=255;
max=0;
for(i=0; i<=30; ++i) {
value = Read_ADC();
if(value<min)
min=value;
if(value>max)
max=value;
printf("\n\rMin: %2X Max: %2X\n\r",min,max);
} while (TRUE);
I am using 3.214
Smile
PostPosted: Tue Jan 24, 2006 5:16 am     Reply with quote
Have a look in your 18F452.h file, and see if the definition is there. The code should compile fine, provided the define is present for 'ALL_ANALOG', so the error suggests that the file has been edited/corrupted, or perhaps the compiler is picking up another file of the same name, that does not contain the required definition. A search for all files called '18F452.h', and a quick check what is in them, should find the problem.
PostPosted: Tue Jan 24, 2006 6:24 am     Reply with quote
The proper command is
SETUP_ADC_PORTS(ALL_ANALOG);
PostPosted: Tue Jan 24, 2006 6:53 am     Reply with quote
No.
Though I prefer 'SETUP_ADC_PORTS', 'SETUP_PORT_A', has been available as an 'alias' for some time, and predates his compiler version. If you look in the .h file, you will get:
"// ADC Functions: SETUP_ADC(), SETUP_ADC_PORTS() (aka SETUP_PORT_A),"
This is not his problem.
PostPosted: Tue Jan 24, 2006 7:14 am     Reply with quote
You are correct, I did not know that.
I compiled this code under 3.214 with no errors.
You are correct about it must be something corrupt in the source file.
PostPosted: Tue Jan 24, 2006 7:57 am     Reply with quote
I can't actually understand 'why' they have this alias. It strikes as another way to increase the possible 'permutations' of code that can go wrong....
My own suspicion, is that there is another file called '18f452.h', probably created by the user for something, which is causing the problem.
rnielsen
PostPosted: Tue Jan 24, 2006 10:34 am     Reply with quote
I just compiled both commands with v3.214 and they came out with the same result.
.................... setup_port_a(all_analog);
0A16: BCF FC1.0
0A18: BCF FC1.1
0A1A: BCF FC1.2
0A1C: BCF FC1.3
.................... setup_adc_ports(all_analog);
0A1E: BCF FC1.0
0A20: BCF FC1.1
0A22: BCF FC1.2
0A24: BCF FC1.3
Ronald
