I check the send values via Hyper Terminal.
And thats my problem:
At the slave output I am getting permanently the address of the PIC |a0||a0|... and so on and not the |EE||EE|....
And at the master output |ff||ff| ....
Is there something wrong with the routines or do I have to clear the input buffer of the slave PIC? Because I think the code "should" work. I also screened the signal on the scope. And till the write command everything looks fine.
It would be very nice if somebody could help me. I tried it now to long without result.
BYE
Posted: Mon Jan 23, 2006 10:35 am
My suggestion is to get the CCS example EX_SLAVE.C, working first.
It's in this folder:
c:\Program Files\Picc\Examples
