replacement output_low/high(VARIABLE) code issues...
Goto page 1, 2  Next
KamPutty
PostPosted: Thu Jan 05, 2006 9:49 pm     Reply with quote
Hi all,
I was looking for a way to replace the "output_x(CONST)" methods with something that can take a variable. I was given code to do this by someone from this board (thanks if I forgot to thank you).
I have changed the code to make work for the pic18f452 chip (possibly all the 18's?).
I have expanded the one method to 2, where one is for specific pin changes, and one that is for the whole port. Saves me from goiing thru each pin, and instead just providing a 8 bit value to be ALL the pins for a given port.
The issue that I am having is that when I do a PORT update (all 8 bits), the highest bit, RC7, in my case is ALWAYS active/on. If I do a single pin deactive of RC7 RIGHT after the port update it's okay....
Here's the code...
#include <18F452.h>
#device *=16
#device adc=10
#fuses XT,NOWDT,NOPROTECT,NOLVP
#use delay(clock = 4000000)
//#use rs232(stream=SERIAL, baud=9600, xmit=PIN_C6, rcv=PIN_C7, parity=N, bits=8)
//#zero_ram
#case
#fill_rom 0xdead
#id   checksum
#define PORT_A  PIN_A0
#define PORT_B  PIN_B0
#define PORT_C  PIN_C0
#define PORT_D  PIN_D0
#define PORT_E  PIN_E0
#define TRIS_OFFSET 0x12
// do_pin_io() --
// This function will perform an i/o action on a CCS pin.
// The ccs_pin parameter must be a value defined in the .H
// file for your PIC, such as PIN_B0, PIN_C5, etc.
// The CCS pin value and state can be passed in variables.
// The action must be as follows:
// Action = 0:  Set the specified pin = 0
// Action = 1:  Set the specified pin = 1
// Action = 2:  Read the specified pin and return
//                   its value (0 or 1).
// Any action value > 2 will be treated as 2.  For actions
// 0 and 1, the return value has no meaning (but 0 is
// returned).
// This function only works for the 18F series PICs, in
// which the i/o ports are at addreses 0xf80 ~ 0xf84, and the
// corresponding TRIS registers are known to be at
// 0xf92 ~ f96, respectively.
int8 do_pin_io(int16 ccs_pin, int8 action)
    int16 io_port;
    int16 io_tris;
    int16 bitmask;
    int8 retval;
    int8 const bitmask_table[] = {0x01,0x02,0x04,0x08,0x10,0x20,0x40,0x80};
    retval = 0;
    io_port = ccs_pin >> 3;                 // Get the i/o port address
    bitmask = bitmask_table[ccs_pin & 7];   // get mask
    io_tris=io_port+TRIS_OFFSET;            // 0x12 is the offset
    if(action < 2)  // Is this an output action ?
        *(io_tris) &= ~bitmask; // Set TRIS = output
        if(action)
            *io_port |= bitmask;    // Set pin = 1
            *io_port &= ~bitmask;   // Set pin = 0
    else  // If not, we will read the pin  (action = 2)
        *(io_tris) |= bitmask;     // Set TRIS = input
        retval = !!(*io_port & bitmask);  // Read pin (ret. 0 or 1)
    return(retval);   // This only has meaning if action = 2
void do_port_io(int16 port, unsigned int8 value)
    unsigned int16 io_port;
    unsigned int16 io_tris;
    io_port=port >> 3;                 // Get the i/o port address
    *io_tris = ~value;
    *io_port = value;
void testLEDs()
    int digit;
    int LEDCount=8; // base 1
    int8 x;
    int8 y=0;
    //                     1   2    3    4    5    6    7    8
    int8 const mask[] = {0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f};
    setup_adc_ports(NO_ANALOGS);
        for(x=0; x<LEDCount; x++)
            do_port_io(PORT_C, mask[x]);    // Set the segments
//            do_pin_io(PIN_C7, 0);           // unless I do this, C7 is ALWAYS active!
            do_pin_io(PIN_D0+x, 0);         // turn on digit (using Common Cathode LED's)
            do_pin_io(PIN_D0+x, 1);         // turn off digit
    testLEDs();
#ignore_warnings 203
#ignore_warnings none
Any thoughts? Replacement code?
~Kam (^8*
PostPosted: Thu Jan 05, 2006 10:50 pm     Reply with quote
Is this the exact code that you tested ? Are you certain that you
had the #use rs232() statement commented out when you did the test ?
KamPutty
yup...
PostPosted: Fri Jan 06, 2006 12:38 am     Reply with quote
Sadly, yes, it was commented out. What's strange is regardless on what I do in the "do_port_io" method, RC7 is high (I know this since the DP led it on). BUT, if I call the do_pin_io method right after on RC7 set to "0", the DP goes off!
BTW, I am prototyping on a PicDem 2 Plus board, and RC6 and RC7 are wired to the on board MAX232. There is nothing plugged into the DB9 (ie. no serial).
I thought that this may be it, but why would setting the bit (rc7) after the port _io method make a difference? Am I bypassing something and it's resetting to "default" when a port change happens, but the pin level overrides that?....
~Kam (^8*
KamPutty
Replacement code?
PostPosted: Fri Jan 06, 2006 11:05 am     Reply with quote
Hi all,
I'm still stumped! Does anyone one have some code to just update a port, all 8 bits using a user sent variable?
ie. updatePort(int8 port, unsigned int8 value);
I want to replace my port update method (it's the one that always has a high RC7)...
Thanks all,
~Kam (^8*
PostPosted: Fri Jan 06, 2006 11:35 am     Reply with quote
The MAX232 is driving Pin C7 high. MAX232 does an inversion.
There is a pull-down resistor built-in on the Rx input of the MAX232.
So that puts a logic-low into the Rx side, and it is inverted to become
a logic high level going to pin C7 on the PIC.
According to the MAX232 data sheet, the TTL/CMOS output of the
MAX232 can typically source 30 ma if the output is shorted.
You should not be trying to make pin C7 into a PIC output pin.
It conflicts with the output pin of the MAX232.
Ringo42
PostPosted: Thu Jan 19, 2006 9:42 pm     Reply with quote
I'm trying to use the code above but I can't get it to work. I copied it exactly and got nothing. So I shrunk it down a little to post here. When the pic boots it flashes the leds once, then just keeps printing "Working" but no more leds flash. There are a couple lines that my olod compiler does not like, but I don't think they should kill it.
What am I missing?
Ringo
#include "18f452.h"
//using CCS PCW C Compiler, Version 3.050
#fuses hs,nowdt,noprotect,put,lvp
#device *=16
#device adc=10
#use rs232(baud=19200, xmit=PIN_C6, rcv=PIN_C7, parity=N, bits=8)
//#zero_ram --this does not work with my old compiler version
//#case
//#fill_rom 0xdead--this does not work with my old compiler version
int16 io_port;
int16 io_tris;
int16 bitmask;
int8 retval;
retval = 0;
if(action)
void testLEDs()
int digit;
int8 x;
do_pin_io(PIN_D2, 1); // turn on digit (using Common Cathode LED's)
do_pin_io(PIN_D4, 1); // turn on digit (using Common Cathode LED's)
do_pin_io(PIN_D5, 1); // turn on digit (using Common Cathode LED's)
do_pin_io(PIN_D6, 1); // turn on digit (using Common Cathode LED's)
do_pin_io(PIN_D7, 1); // turn on digit (using Common Cathode LED's)
delay_ms(250);
do_pin_io(PIN_D2, 0); // turn off digit
delay_ms(250);
do_pin_io(PIN_D4, 0); // turn off digit
delay_ms(250);
do_pin_io(PIN_D5, 0); // turn off digit
delay_ms(250);
do_pin_io(PIN_D6, 0); // turn off digit
delay_ms(250);
do_pin_io(PIN_D7, 0); // turn off digit
delay_ms(250);
//just to prove the leds work
printf("workingabcd\r\n");
output_high(PIN_D2);
output_high(PIN_D4);
output_high(PIN_D5);
output_high(PIN_D6);
output_high(PIN_D7);
output_low(PIN_D2);
output_low(PIN_D4);
output_low(PIN_D5);
output_low(PIN_D6);
output_low(PIN_D7);
//#ignore_warnings 203--this does not work with my old compiler version
printf("working\r\n");
testLEDs();
//#ignore_warnings none --this does not work with my old compiler version
Ringo Davis
PostPosted: Thu Jan 19, 2006 10:03 pm     Reply with quote
I don't have PCH vs. 3.050. The oldest version I have is 3.148.
Your code worked with that version. I tested it on a PicDem2-Plus,
and I changed the LED pins to B0-B3 to fit that board.
Ringo42
PostPosted: Thu Jan 19, 2006 10:15 pm     Reply with quote
Damn, I guess that means it is a compiler thing. I'm printing out the values calculated for IO_port and IO_Tris and they are correct so it must be the pointer operation that is failing. Is there a way to do it without pointers?
Ringo Davis
PostPosted: Thu Jan 19, 2006 10:29 pm     Reply with quote
Post the ASM code from your .LST file for the do_pin_io() function.
Don't post the whole list file -- just that function.
Ringo42
PostPosted: Thu Jan 19, 2006 10:42 pm     Reply with quote
.................... int8 do_pin_io(int16 ccs_pin, int8 action)
.................... int16 io_port;
.................... int16 io_tris;
.................... int16 bitmask;
.................... int8 retval;
.................... int8 const bitmask_table[] = {0x01,0x02,0x04,0x08,0x10,0x20,0x40,0x80};
0004: ADDLW 16
0006: MOVWF FF6
0008: MOVLW 00
000A: MOVWF FF7
000C: BTFSC FD8.0
000E: INCF FF7,F
0010: TBLRD*
0012: MOVF FF5,W
0014: RETURN 0
0016: DATA 01,02
0018: DATA 04,08
001A: DATA 10,20
001C: DATA 40,80
.................... retval = 0;
008C: CLRF 0F
.................... // printf("ccspin=%ld\r\n",ccs_pin);
.................... io_port = ccs_pin >> 3; // Get the i/o port address
008E: BCF FD8.0
0090: RRCF 07,W
0092: MOVWF 0A
0094: RRCF 06,W
0096: MOVWF 09
0098: RRCF 0A,F
009A: RRCF 09,F
009C: RRCF 0A,F
009E: RRCF 09,F
00A0: MOVLW 1F
00A2: ANDWF 0A,F
.................... // printf("IO_PORT=%ld\r\n",io_port); //3971=f83 for D
.................... bitmask = bitmask_table[ccs_pin & 7]; // get mask
00A4: MOVF 06,W
00A6: ANDLW 07
00A8: MOVWF 10
00AA: MOVF 07,W
00AC: ANDLW 00
00AE: MOVWF 11
00B0: MOVF 10,W
00B2: CALL 0004
00B6: MOVWF 01
00B8: CLRF 0E
00BA: MOVFF 01,0D
.................... io_tris=io_port+TRIS_OFFSET; // 0x12 is the offset
00BE: MOVLW 12
00C0: ADDWF 09,W
00C2: MOVWF 0B
00C4: MOVLW 00
00C6: ADDWFC 0A,W
00C8: MOVWF 0C
.................... // printf("IO_tris=%ld\r\n",io_tris); //3989=f95 for D
.................... if(action < 2) // Is this an output action ?
00CA: MOVF 08,W
00CC: SUBLW 01
00CE: BTFSS FD8.0
00D0: GOTO 0130
.................... *(io_tris) &= ~bitmask; // Set TRIS = output
00D4: MOVF 0B,W
00D6: MOVWF FE9
00D8: MOVFF 0C,FEA
00DC: MOVF 0E,W
00DE: MOVWF 03
00E0: COMF 03,F
00E2: MOVF 0D,W
00E4: XORLW FF
00E6: ANDWF FEF,W
00E8: MOVWF 00
00EA: MOVLW 00
00EC: ANDWF 03,F
00EE: MOVWF FEF
.................... if(action)
00F0: MOVF 08,F
00F2: BTFSC FD8.2
00F4: GOTO 0110
.................... *io_port |= bitmask; // Set pin = 1
00F8: MOVF 09,W
00FA: MOVWF FE9
00FC: MOVFF 0A,FEA
0100: MOVF FEF,W
0102: IORWF 0D,W
0104: MOVWF 00
0106: MOVF 0E,W
0108: MOVWF 03
010A: MOVWF FEF
.................... else
010C: GOTO 012C
.................... *io_port &= ~bitmask; // Set pin = 0
0110: MOVF 09,W
0112: MOVWF FE9
0114: MOVFF 0A,FEA
0118: MOVF 0E,W
011A: MOVWF 03
011C: COMF 03,F
011E: MOVF 0D,W
0120: XORLW FF
0122: ANDWF FEF,W
0124: MOVWF 00
0126: MOVLW 00
0128: ANDWF 03,F
012A: MOVWF FEF
.................... else // If not, we will read the pin (action = 2)
012C: GOTO 0162
.................... *(io_tris) |= bitmask; // Set TRIS = input
0130: MOVF 0B,W
0132: MOVWF FE9
0134: MOVFF 0C,FEA
0138: MOVF FEF,W
013A: IORWF 0D,W
013C: MOVWF 00
013E: MOVF 0E,W
0140: MOVWF 03
0142: MOVWF FEF
.................... retval = !!(*io_port & bitmask); // Read pin (ret. 0 or 1)
0144: MOVF 09,W
0146: MOVWF FE9
0148: MOVFF 0A,FEA
014C: MOVF FEF,W
014E: ANDWF 0D,W
0150: MOVWF 00
0152: MOVF 0E,W
0154: ANDLW 00
0156: MOVWF 03
0158: IORWF 03,W
015A: MOVLW 00
015C: BTFSS FD8.2
015E: XORLW 01
0160: MOVWF 0F
.................... return(retval); // This only has meaning if action = 2
0162: MOVF 0F,W
0164: MOVWF 01
0166: RETLW 00
Ringo Davis
PostPosted: Sat Jan 21, 2006 1:52 am     Reply with quote
I think I see the problem. When he converted my code for the 18F
series PICs, he changed "bitmask" into a 16-bit variable. That's wrong.
It should be int8. For later versions of the compiler, this doesn't hurt
anything. But for your version, PCH 3.050, it causes a problem.
It generates incorrect code. Try changing the declaration of "bitmask",
shown below in bold, back to an "int8". See if that fixes the problem.
I don't have your version of the compiler, or anything close to it, so I
can't test this. But I think there's a good chance that it might fix it.
int16 io_port;
int16 io_tris;
int16 bitmask; // Change this to an int8
int8 retval;
Ringo42
PostPosted: Sun Jan 22, 2006 10:41 pm     Reply with quote
Thanks, That fixed the problem in the simple example, now I have another question.
Why does this work;
int16 ccs_pin;
ccs_pin=PIN_D2;
but this does not;
int return_value,pinn,state;
int16 ccs_pin;
int16 pin_table[] = {PIN_D2, PIN_C3, PIN_C4, PIN_C5, PIN_D4,
PIN_D5, PIN_D6, PIN_D7, PIN_B2, PIN_E1};
ccs_pin = pin_table[pinn];
It worked fine in the 877 version when everythig above was 8 bit, but not in the 18f version.
Ringo
Ringo Davis
PostPosted: Mon Jan 23, 2006 12:25 am     Reply with quote
Can you post the code for the "non-simple" example ? Except don't post
the do_ccs_pin() function. I'll assume you're using the working version.
If you post the example code, then I can compile it and look at it.
Ringo42
PostPosted: Mon Jan 23, 2006 10:11 am     Reply with quote
Here is the entire function. the main difference between the simple example is that I don't pass teh pin and state into teh function, I grab them from a serial buffer and do the look-up table there.
If I use the line //ccs_pin=PIN_D2; then that pin works, so the problem is narrowed down to teh ccs_pin = pin_table[pinn]; line.
Ringo
int GPIO(void)
int16 ccs_pin;
int16 io_port;
int16 io_tris;
int8 bitmask;
int8 retval;
int p,s;
p=2;
s=3;
do
p+=3;
s=p+1;
pinn=SERIAL_BUFFER[p]-0x30;
state=SERIAL_BUFFER[s]-0x30;
printf("pinn=%d\r\n",pinn);
printf("state=%d\r\n",state);
if(serial_buffer[p+1]=='\r')
state=2;
if(serial_buffer[s-1]=='\r')
NACK();
return;
// ccs_pin=PIN_D2;
retval = 0;
if(state < 2) // Is this an output action ?
if(state==1)
printf("setting a 1\r\n");
printf("setting a 0\r\n");
else // If not, we will read the pin (state = 2)
printf("%d",retval);
return(retval);
} while(SERIAL_BUFFER[s+1] !='\r');
Ringo Davis
PostPosted: Mon Jan 23, 2006 2:27 pm     Reply with quote
Make a complete test program that just tests the serial buffer problem.
The pin i/o function doesn't have anything to do with that problem.
You can cut that code out completely. You also need to explain your
serial format. You have offsets into your data stream called s and p.
You should post an example of your full data stream. Post why you
have these offsets in there. Focus in on the serial protocol problem.
Goto page 1, 2  Next
Page 1 of 2
