modification tp LCD:C driver
Ezequiel
PostPosted: Thu Jan 30, 2003 9:29 pm     Reply with quote
Does anybody tried to modify the LCD.C driver, so it can be use with a 4 lines x 20 chars LCD?
Zeke
___________________________
Original Post ID: 11143
Shane Rowell
Re: modification tp LCD:C driver
PostPosted: Fri Jan 31, 2003 11:56 am     Reply with quote
Zeke,
I think that it should not be that big of an effort.
You will need to add the following:
define lcd_line_three 0x14
define lcd_line_four 0x54
These are the ram locations of the first character in the third and fourth lines respectively.
You will also need to modify the lcd_gotoxy function to allow for the four possible changes. If you are using the '\n' command you will have to modify it. I typically just use the lcd_gotoxy function.
Let me know if there is anything more I can help with.
Shane
:=Hello,
:= Does anybody tried to modify the LCD.C driver, so it can be use with a 4 lines x 20 chars LCD?
:=Thanks
:=Zeke
:=Hello,
:=Thanks
:=Zeke
Original Post ID: 11168
jruibarroso
View user's profile Send private message Send e-mail MSN Messenger
PostPosted: Sun Jan 22, 2006 5:02 am     Reply with quote
if it was not much trouble, would you post here the lcd.c complete with this modification for 4 lines LDC ?? i'm kind a newby and i'm kind a problems to do this, thank you
specialk
PostPosted: Sun Jan 22, 2006 10:44 am     Reply with quote
In your LCD420.c file, change:
#byte lcd = 6                        // This puts the entire structure
                                     // on to port B (at address 6)
to
#if defined(__PCH__)
#if defined use_portb_lcd
   #byte lcd = 0xF81                   // This puts the entire structure
#else
   #byte lcd = 0xF83                   // This puts the entire structure
#else
   #byte lcd = 6                  // on to port B (at address 6)
#else
   #byte lcd = 8                 // on to port D (at address 8)
and use
void lcd_gotoxy( BYTE x, BYTE y) {
   BYTE address;
   switch(y) {
     case 1 : address=0x80;break;
     case 2 : address=0xc0;break;
     case 3 : address=0x94;break;
     case 4 : address=0xd4;break;
   address+=x-1;
   lcd_send_byte(0,address);
-special [k]
