how to get 0-360 degree binary information from pc
asunca
PostPosted: Sat Jan 21, 2006 3:37 am     Reply with quote
i want to get 0-360 degree information from pc via serial port. but i dont know how to get the bytes into pic. this will not be an interrupt but polling. should i send ascii for example 268 degree as ascii2,ascii6,ascii8? or a different way (ie.using 9bits maybe) . using software control how is this accomplished? this will control a dc geared motor with encoder..
and the visual basic program?? how can i write it?
* datasheet tells built in usart can buffer up to 3 bytes..(16f877)
kender
View user's profile Send private message Send e-mail Visit poster's website Yahoo Messenger
Re: how to get 0-360 degree binary information from pc
PostPosted: Sat Jan 21, 2006 3:44 pm     Reply with quote
asunca wrote:
this will not be an interrupt...
Why not? Smile
asunca
PostPosted: Sun Jan 22, 2006 3:41 am     Reply with quote
i dont think interrupt is necessary. i have a 8channel servo controller downloaded from web. i would like to benefit from it in my project because i dont know visual basic. i know how it works (one byte command, one byte data). i need the second byte only. but it is one byte and 0-255 degree can be represented. i want 0-360 and i dont know to get the byte using getc().
kender
PostPosted: Sun Jan 22, 2006 4:15 pm     Reply with quote
Sounds like there are three separate problems. Unfortunately, I don't know what software are you planning to use; if you post a link, I'll take a look at it. But your software might be sending you 0-360deg as one byte. That way 1 deg corresponds to 0.7083 in the data byte.
