dbrown
18F4450 Fuses |
Posted: Fri Jan 20, 2006 8:00 pm |
I am trying the us_ex_serial example, however I am having problems with two things. I am using compiler version 3.242. I have tried several different crystals, 4 mhz, 20 mhz, and 48 mhz. I have set the use delay to reflect the applicable crystal frequency. When I connect the pic to the serial port I get garbled characters, an indication to me that the baud rate is not correct. The other problem is that the Win 2K computer never seems to find the pic. I have installed the usb.sys files in windows system folder, and I have also copied the .inf files to the system folder. Is there somewhere that I can find a definition for the fuses.
HS, HSPLL are they two separate purposes? I assume HS is for crystal speed greater than 4 mhz, and HSPLL is part of the High speed phase lock loop.
I do not undestand the purpose of the usbdiv fuse.
If I understand correctly the cpudiv1, pll5 all relate to the chosen crystal.
Does the vregen fuse enable the internal 3.3V regulator.
I have read the data sheet for the '4550, for 4 mhz, why does it list xt,hs,ec,ecio in one cell with clock divisions, and then hspll, ecpll, xtpll, ecpio in another cell with clock divisions again?
Any help would be appreciated.
Thank you
David Brown |
dbrown
Correction to first email |
Posted: Fri Jan 20, 2006 8:06 pm |
The pic I am using is a 18F4550, not 18F4450, that was a typo. |
Posted: Fri Jan 20, 2006 9:34 pm |
Start with a very simple program, just to get the RS-232 serial port
working. Example:
Code: | #include <18F4550.H>
printf("Hello World\n\r");
dbrown
18F4550 |
Posted: Fri Jan 20, 2006 10:05 pm |
I tried the simple program as listed above, and the serial interface works fine. If I want to use the usb with a 4 mhz crystal then I need to set pll/1 and cpudiv0.
Thanks for your help PCM.
Dave |
arys
Posted: Fri Jan 11, 2008 2:20 am |
sorry for interrupt but where can I see the "hello world" sentence? |
Posted: Fri Jan 11, 2008 3:56 am |
Going back to the first question, a 48MHz crystal, is not legitimate. You can use a 48Mhz external _oscillator_, but not a crystal. The internal oscillator is not specified to run above 25MHz.
Now, the 4MHz crystal, may also give problems. Though 'legitimate', on these PICs, I have seen problems with them. For some reason, the internal USB PLL, can behave 'oddly', with quite a few crystals. The chip works, and is clocking at the right rate, but the USB becomes unreliable.
So, I'd say, use a multiple of 4MHz. The 20MHz crystal (or an 8MHz, 12MHz etc.), would be my choice.
For the 20MHz crystal, you have the choice of running the processor, at 48MHz, 24MHz, 20MHz, 16MHz, 12MHz, 10MHz, 6.66MHz, or 5MHz. The normal fuse settings are:
HSPLL PLL5 CPUDIV1 USBDIV - 48MHz CPU
HSPLL PLL5 CPUDIV2 USBDIV - 24MHz CPU
HS PLL5 CPUDIV1 USBDIV - 20MHz CPU
HSPLL PLL5 CPUDIV3 USBDIV - 16MHz CPU
HSPLL PLL5 CPUDIV4 USBDIV - 12MHz CPU
HS PLL5 CPUDIV2 USBDIV - 10MHz CPU
HS PLL5 CPUDIV3 USBDIV - 6.66MHz CPU
HS PLL5 CPUDIV4 USBDIV - 5MHz CPU
The 'key' is that the USB PLL, is _always_ used, provided the 'USBDIV' fuse is selected. If 'HS' is selected, the CPU clock comes from the crystal, while if 'HSPLL' is selected, the CPU clock comes from the USB PLL. PLL5, says divide the master clock by 5, to get the required 4MHz to feed the USB PLL. Then the 'CPUDIV' numbers, give the division used from the clock source (either the external crystal, or the USBPLL/2), to feed the CPU.
If the 'USBDIV' fuse is not selected, the USB clock comes directly from the external clock.
Start by getting the oscillators 'right'. Setup whichever one you want, set the 'clock' statement to match the CPU frequency, and run a simple 'output one pin high for one second, then low for one second' type program, to verify that the CPU _is_ running at the selected frequency. Once this is running, substitute these clock fuse settings, and clock statement, into the UB example, and try this.
As another 'caveat', add more smoothing to the regulator pin, than is specified in the data sheet. I have had problems with some batches of these chips not giving reliable operation. My standard setup now, is a 1uF electrolytic capacitor, in parallel with a 0.1uF ceramic capacitor on the regulator pin, and this (seems) to be reliable.
Yes, VREGEN, enables the internal regulator.
