Assembly to C. Code not working right :(
Kasper
PostPosted: Thu Jan 19, 2006 3:25 pm     Reply with quote
Hi.
I am trying to make a pic16F639 talk to its internal Low Frequency front end via software SPI.
The 639 is identical to a 636 but has an MCP2030 chip in the same package, connected via RC1,2,3.
I have sample code from microchip for their demo board, which is in assembler. I am therefor trying to rewrite it in C. This is where I am running into trouble.
I hooked up a couple of unused IO's to an RS232 port in so I can monitor the what is happening internally, which tells me this
AFE[0] = 0xA0 -- SPI_READ[0] = 0x0000
AFE[1] = 0x00 -- SPI_READ[1] = 0x0000
AFE[2] = 0x00 -- SPI_READ[2] = 0x0000
AFE[3] = 0x00 -- SPI_READ[3] = 0x0000
AFE[4] = 0x00 -- SPI_READ[4] = 0x0000
AFE[5] = 0x10 -- SPI_READ[5] = 0x0000
AFE[6] = 0x4F -- SPI_READ[6] = 0x0000
the SPI_reads should return the AFE data, shifted left one bit. As you can see, it is not happening.. I think I have stared myself blind looking at this, so if anyone has any suggestions it would be most welcome Smile
I can upload the entire Assembly if needed, but it is rather long. These are the sections which I have failing :(
   #define   AFECS   PORTC,1   ; Chip select output
   #define   SCK   PORTC,2   ; SPI Clock Output
   #define   SDIO   PORTC,3   ; Serial Data Input/Output
   #define   LFDATA   PORTC,3   ; Low Frequency Data IN
pin defines.
Set_up_AFE_Registers
   bsf   STATUS,RP0
   movfw   TRISC
   andlw   b'11000000'      ; chuck, Setup SDIO,SCLK, and CS as outputs
   movwf   TRISC         ;
   bcf   STATUS,RP0
;      Register 0: 0000-0001 - 0 (parity)
   movlw   WriteCommand+GeneralOptions+((AFEConfig0>>8)&0x01)
   movwf   SPIBufH
   movlw   AFEConfig0&0xFF
   movwf   SPIBufL
   call   ShiftOutSPIBuffer
;      Verify Register 0
   movlw   ReadCommand+GeneralOptions
   movwf   SPIBufH
   movlw   0x00
   movwf   SPIBufL
   call   ShiftInSPIBuffer
   movfw   SPIBufL
   xorlw   AFEConfig0&0xFF
   btfss   STATUS,Z
   retlw   0x01
;      Register 1: 0000-0000 - 1 (parity)
this repeats for each register, trying to save space here Smile
; Subroutine: ShiftOutSPIBuffer
; Description: This routine is used to shift data out of the microcontroller
;               onto the SPI bus.
;Notes:
;1.   This routine assumes 16-bit data is in SSPBufH and SSPBufL already.
;3.   Control the ports as follows:
;      Clear SCK/ALERT
;      Clear chip select
;Loop
;      Set or clear LFDATA/SDIO pin.
;      Set SCK/ALERT
;      Clear SCK/ALERT
;      Goto Loop 16 times
;      Set chip select
;Count00
ShiftOutSPIBuffer
   movlw      .16
   movwf      Count00
   bcf      SCK
   bcf      AFECS
ShiftOutLoop
   rlf      SPIBufL, f
   rlf      SPIBufH, f
   btfss      STATUS, C
   bcf      SDIO
   btfsc      STATUS, C
   bsf      SDIO
   bsf      SCK
   bcf      SCK
;   CLRWDT
   decfsz      Count00, f
   goto      ShiftOutLoop
   bsf      AFECS
   bcf      AFECS
   return
; Subroutine: ShiftInSPIBuffer
; Description: This routine is used to shift data into the microcontroller
;               from the SPI bus.
;Notes:
;1.   This routine loads 16-bit data into the SSPBufH and SSPBufL registers.
;      Clear SCK/ALERT
;      Clear chip select
;Loop
;      Set SCK/ALERT
;      Shift in the LFDATA/SDIO pin value.
;      Clear SCK/ALERT
;      Set chip select
;Count00
ShiftInSPIBuffer
   movlw      .16
   movwf      Count00
   bsf      STATUS,RP0
   bsf      TRISC,3      ;Set SDIO as an input
   bcf      STATUS,RP0
   bcf      SCK
   bcf      AFECS
ShiftInLoop
   bsf      SCK
   btfss      SDIO
   bcf      STATUS, C
   btfsc      SDIO
   bsf      STATUS, C
   rlf      SPIBufL, f
   rlf      SPIBufH, f
   bcf      SCK
;   CLRWDT
   decfsz      Count00, f
   goto      ShiftInLoop
   bsf      AFECS
   bcf      SCK
   bsf      STATUS,RP0
   bcf      TRISC,3      ;Set SDIO as an output
   bcf      STATUS,RP0
   return
So here is my C code. as my first attempt using fancier looking functions failed, I tried duplicating the assembly as much as possible, yet I am still failing :(
#use rs232(baud=9600,parity=N,xmit=PIN_C0,rcv=PIN_C4,bits=8)
#include "interupt.c" // file with the Interrupt Service Routines in it.
    setup_timer_0(RTCC_INTERNAL|RTCC_DIV_256);
    setup_timer_1(T1_DISABLED);
    output_high(LF_CS);
//   output_low(LF_ALERT);
//   output_float(LF_ALERT);//
if( Set_Up_AFE_Registers()==0) {
   output_low(PIN_A5);
//  port_a_pullups(true);
//  set_tris_a(0x01); // only pin 1 is input.used to wake up the processor from the low frequency front end.
//   enable_interrupts(INT_EXT);
//  enable_interrupts(GLOBAL);
   printf("\n\r");
while(TRUE) {
   sleep();
   }//END WHILE
}// END MAIN
int Set_Up_AFE_Registers(void) {
int errorlevel=0;
int16 SPIREAD,TXDATA;
int i,address;
for(i=0;i<7;i++) {
address = SPI_WRITE_COMMAND | i;      //WRITE AFE Registers
TXDATA = make16(address,AFE[i]);
TXDATA = TXDATA << 1;
TXDATA = parity16(TXDATA);
shift_out_SPI(TXDATA);               //READ AFE Registers
address = SPI_READ_COMMAND | i;         // Generate the SPI Read command
TXDATA = make16(address,0x00);
//TXDATA = parity16(TXDATA); .. seems the sample source code does not have parity on the read byte.
shift_out_SPI(TXDATA); // Send the read command
SPIREAD=shift_in_spi();// now clock the data back in
   printf("\r\nAFE[%d]      = 0x%X  -- ",i,AFE[i]);
   printf("SPI_READ[%d] = 0x%LX",i,SPIREAD);
return errorlevel;
void shift_out_SPI(int16 DATA) {
int i;
output_low(LF_CS);
for(i=0;i<16;i++) {
if(bit_test(DATA,0)) {
      output_high(LF_DATA);
   else {
      output_low(LF_DATA);
output_high(LF_ALERT);
 DATA = DATA >> 1;
}//end for
output_high(LF_CS);
//output_low(LF_CS);
}//end function
int16 shift_in_spi(void){
int16 RETDATA;
int DATA[2];
int i;
//set_tris_c(SPI_READ_Direction);
//output_float(LF_DATA);
output_low(LF_CS);
for(i=0;i<16;i++) {
      shift_left(DATA,2,input(LF_DATA));
output_high(LF_CS);
//set_tris_c(SPI_WRITE_Direction);
RETDATA=make16(DATA[1],DATA[0]);
return RETDATA;
} // end function
int16 parity16(int16 DATA) {
// Add parity to the DATA to be send to the Low frequency front end.
// the parity is ODD, and only on the 8 data bits, which are located at'D' "CCCAAAADDDDDDDDP"
//the parity is added in the LSB position.
int i;
int count=0;
int16 ReturnData;
ReturnData= DATA;
   for(i=0;i<8;i++) {
      if(DATA& 0x0001) {
         count++;
      DATA=DATA>>1;
if(count%2 == 0){
   ReturnData = (ReturnData | 0x0001); // the 0x0002 is because we check the lsb of the data, which is not in the right most position, as that is where the parity bit is.
return ReturnData;
here is my pinout.h file
//RA_TRIS   EQU   B'00111111'
//RC_TRIS   EQU   B'00001110'
//   ENDIF
//   IFDEF P16F639
//                    _________
//                Vdd | 1  20 | Vss
//                 S0 | 2  19 | S5/SlowFall
//                 S1 | 3  18 | S4/LFDint
//                 S2 | 4  17 | S3/SHIFT/RFEN
//               DATA | 5  16 | LED1n          16F639
//              LED2n | 6  15 | RC1/CSn
//    RC3/LFDATA/SDIO | 7  14 | RC2/SCLK/Alert
//               Vddt | 8  13 | Vsst
//                LCZ | 9  12 | LCCOM
//                LCY | 10 11 | LCX
   #define   S0   PORTA,5      // S0 BUTTON INPUT
   #define   S1   PORTA,4      // S1 BUTTON INPUT
   #define   S2   PORTA,3      // S2 BUTTON INPUT
   #define   S3   PORTA,2      // S3 BUTTON INPUT
   #define S4   PORTA,1      // S4 BUTTON INPUT
   #define LFDint   PORTA,1
   #define S5   PORTA,0      // S5 BUTTON INPUT
   #define   RFEN   PORTA,2   // RF ENABLE OUTPUT
   #define   RFENtris   TRISA,2
   #define   SHIFT   PORTA,2   // SHIFT BUTTON INPUT
   #define   LED   PORTC,0   // LED output
   #define   AFECS   PORTC,1   // Chip select output
   #define   SCK   PORTC,2   // SPI Clock Output
   #define   SDIO   PORTC,3   // Serial Data Input/Output
   #define   LFDATA   PORTC,3   // Low Frequency Data IN
   #define ValidLED   PORTC,4   // LED output
   #define   RFOUT   PORTC,5   // RF DATA OUTPUT
#define LF_CS PIN_C1
#define LF_ALERT PIN_C2
#define LF_DATA PIN_C3
#define SPI_CLK_DELAY 1
//Command(3 bits) address(4 bits) parity(1 bit) Odd Parity
#define SPI_CLAMP_ON          0x00
#define SPI_CLAMP_OFF          0x10
#define SPI_ENTER_SLEEP       0x20
#define SPI_AGC_PRESERVE_ON      0x30
#define SPI_AGC_PRESERVE_OFF   0x40
#define SPI_SOFT_RESET         0x50
#define SPI_READ_COMMAND      0x60
#define SPI_WRITE_COMMAND       0x70 // first 3 bits should be 111, followed by 4 address bits
// SPI Addresses
#define Config_Byte_0          0x00
#define Config_Byte_1          0x01
#define Config_Byte_2          0x02
#define Config_Byte_3          0x03
#define Config_Byte_4          0x04
#define Config_Byte_5          0x05
#define Colum_Parity           0x06
#define AFE_Status             0x07
#define STX 0x02
#define EOT 0x03
//#define TRUE 0x01
#define SPI_READ_Direction      0x08
#define SPI_WRITE_Direction      0x00
// Analogue Front End Configuration Table
// SGAFE Default Register Values
//      Default Mode:Wake-up filter disabled. MODSIG= 0, Enable Ch-X only. 25% mod depth.
//   Register 0: 1010-0001 - 0 (parity)
//   #define   AFEConfig0   0b10100000   //filter=enabled --> 2ms+2ms
//   Register 1: 0000-0000 - 1 (parity)
   #define   AFEConfig1   0b00000000
//   Register 2: 0000-0000 - 1 (parity)
   #define   AFEConfig2   0b00000000
//   Register 3: 0000-0000 - 1 (parity)
   #define   AFEConfig3   0b00000000
//   Register 4: 0000-0000 - 1 (parity)
   #define   AFEConfig4   0b00000000
//   Register 5: 0001-0000 - 0 (parity)
   #define   AFEConfig5   0b00010000   // modulation depth, default = 75%
//   Register 6: 0100-1111 - 0 (Parity) //  column parity bits
   #define   AFEConfig6   0b01001111   // column parity at defalt mode (75%)
char AFE[7]={AFEConfig0,AFEConfig1,AFEConfig2,AFEConfig3,AFEConfig4,AFEConfig5,AFEConfig6};
#define AFECOLPARITY AFEConfig0 xor AFEConfig1 xor AFEConfig2 xor AFEConfig3 xor AFEConfig4 xor AFEConfig0
PostPosted: Thu Jan 19, 2006 9:00 pm     Reply with quote
I think you should just post one routine that's not working.
Post the assembly, and then the one C routine that doesn't work.
Explain how you know that it doesn't work. Show the
expected output and the actual output.
PostPosted: Fri Jan 20, 2006 2:23 am     Reply with quote
I agree with PCM Programmer. I had a look at the code but didn't spot any obvious errors. It is a lot of code and I don't know what to look for so I stopped checking after 1 minute. If you want quick and usefull responses than give us a small compilable program that shows your problem.
Kasper
PostPosted: Fri Jan 20, 2006 12:08 pm     Reply with quote
I expected this:
as in I program in 0xA0 and read back 0x0000 ( the LSB << 1 contains the data)
I know I posted alot of code Embarassed but I am not sure if it is the write or the read routine which is not working. I verify by using a spare pin as a software RS232 port, printing out debug information..
I will work on it a bit more and see if I can spot where it goes wrong.
Thanks again for looking at it Smile
Kasper
Kasper
PostPosted: Fri Jan 20, 2006 12:16 pm     Reply with quote
ShiftOutSPIBuffer
   movlw      .16
   movwf      Count00
   bcf      SCK
   bcf      AFECS
ShiftOutLoop
   rlf      SPIBufL, f
   rlf      SPIBufH, f
   btfss      STATUS, C
   bcf      SDIO
   btfsc      STATUS, C
   bsf      SDIO
   bsf      SCK
   bcf      SCK
;   CLRWDT
   decfsz      Count00, f
   goto      ShiftOutLoop
   bsf      AFECS
   bcf      AFECS
   return
versus
int i;
output_low(LF_CS);
for(i=0;i<16;i++) {
   else {
 DATA = DATA >> 1;
}//end for
output_high(LF_CS);
}//end function
Anything which stands out as being blatantly wrong?
Looking at the disassembly listing, wow is C ever creating alot more code than assembly
82:                void shift_out_SPI(int16 DATA) {
83:                int i;
84:                output_low(LF_ALERT);
   0D4    1683     BSF 0x3, 0x5
   0D5    1107     BCF 0x7, 0x2
   0D6    1283     BCF 0x3, 0x5
   0D7    1107     BCF 0x7, 0x2
85:                output_low(LF_CS);
   0D8    1683     BSF 0x3, 0x5
   0D9    1087     BCF 0x7, 0x1
   0DA    1283     BCF 0x3, 0x5
   0DB    1087     BCF 0x7, 0x1
86:                for(i=0;i<16;i++) {
   0DC    01BF     CLRF 0x3f
   0DD    083F     MOVF 0x3f, W
   0DE    3C0F     SUBLW 0xf
   0DF    1C03     BTFSS 0x3, 0
   0E0    28F9     GOTO 0xf9
87:                if(bit_test(DATA,0)) {
   0E1    1C3D     BTFSS 0x3d, 0
   0E2    28E8     GOTO 0xe8
88:                      output_high(LF_DATA);
   0E3    1683     BSF 0x3, 0x5
   0E4    1187     BCF 0x7, 0x3
   0E5    1283     BCF 0x3, 0x5
   0E6    1587     BSF 0x7, 0x3
89:                   }
90:                   else {
   0E7    28EC     GOTO 0xec
91:                      output_low(LF_DATA);
   0E8    1683     BSF 0x3, 0x5
   0E9    1187     BCF 0x7, 0x3
   0EA    1283     BCF 0x3, 0x5
   0EB    1187     BCF 0x7, 0x3
92:                   }
93:                output_high(LF_ALERT);
   0EC    1683     BSF 0x3, 0x5
   0ED    1107     BCF 0x7, 0x2
   0EE    1283     BCF 0x3, 0x5
   0EF    1507     BSF 0x7, 0x2
94:                output_low(LF_ALERT);
   0F0    1683     BSF 0x3, 0x5
   0F1    1107     BCF 0x7, 0x2
   0F2    1283     BCF 0x3, 0x5
   0F3    1107     BCF 0x7, 0x2
95:                 DATA = DATA >> 1;
   0F4    1003     BCF 0x3, 0
   0F5    0CBE     RRF 0x3e, F
   0F6    0CBD     RRF 0x3d, F
96:                }//end for
   0F7    0ABF     INCF 0x3f, F
   0F8    28DD     GOTO 0xdd
97:                output_high(LF_CS);
   0F9    1683     BSF 0x3, 0x5
   0FA    1087     BCF 0x7, 0x1
   0FB    1283     BCF 0x3, 0x5
   0FC    1487     BSF 0x7, 0x1
98:                //output_low(LF_CS);
99:                output_float(LF_ALERT);
   0FD    1683     BSF 0x3, 0x5
   0FE    1507     BSF 0x7, 0x2
100:               }//end function
   0FF    1283     BCF 0x3, 0x5
   100    3400     RETLW 0
Shocked
PostPosted: Fri Jan 20, 2006 12:45 pm     Reply with quote
Yes. The ASM code is shifting the 16-bit value to the left.
It shifts the MSB into the CY flag, and then tests it.
So it's shifting out the word "MSB first".
rlf      SPIBufL, f
rlf      SPIBufH, f
btfss    STATUS, C
But your C code is shifting it out "LSB first". You're doing a right-shift
and you're testing the LSB. You're doing the opposite of what the ASM
code is doing.
DATA = DATA >> 1;
Kasper
PostPosted: Fri Jan 20, 2006 1:07 pm     Reply with quote
rlf      SPIBufL, f
rlf      SPIBufH, f
btfss    STATUS, C
code is doing.
DATA = DATA >> 1;
Quoting a famous Cartoon Caracter...
DOH!
thanks PCM.. I am sure that will make one hell of a difference Smile
