Fill hex file with 0xFFs..
sebdey
PostPosted: Tue Jan 17, 2006 2:23 am     Reply with quote
Is there any options in CCS that would permit to create an hex file with all unused memory locations set to FFh instead of having the unused memory location ignored in the hex file.
For example, this is a part of a conventional hex file created by CCS:
:0C06E000A6B2FED7FF0084D50001000C7C
:040800000EEF2FF0D8
The memory between addresses 6E0h (not exactly 6E0h)... and 800h is not used by my program, would it be possible to tell the compiler to fill the hex file with FFh when the memory is not used, i.e. to have
:1006D000040EA66E550EA76EAA0EA76EA682000087
:1006E000A6B2FED7FF0084D50001000CFFFFFFFFFFFF
:1006F000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
:10070000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
:100800000EEF2FF0FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
The aim is to prevent having unused old code fragments in my memory when downloading new code with a bootloader.
Thanks !
PostPosted: Tue Jan 17, 2006 4:50 am     Reply with quote
Depends on how old your compiler is.
On the newer versions, a look in the 'readme' file, for '#fill_rom', will help.
sebdey
PostPosted: Tue Jan 17, 2006 6:34 am     Reply with quote
Thanks, that did it, BUT....
The problem now is following (maybe a compiler bug...):
I place the #fill_rom directive in my header:
#include <18F4620.h>
#device *=16,ADC=8
//On sait que l'on va utiliser les addresses 0x000-0x7FF pour le bootloader, on déplace donc
//le vecteur de reset et les interruptions au bon endroit
#build(reset=0x800,interrupt=0x808)
// On indique que toute la mémoire inutilisée doit être remplie avec des FF (donc effacée...)
#fill_rom 0xFFFF
// On utilise le WDT, contrôlé par software, avec un postscaler de 512 -> Période ~2[s]
#fuses HS,WDT512,NOWDT,NOBROWNOUT,NOLVP,NOPROTECT,NOWRT,PUT,NOPBADEN,NOFCMEN,NOIESO
Then, I declare some memory addresses to hold data for my application:
#define   T_NUM_ADDR         0x0F540
#define   T_CANAL_ADDR      0x0F542
#define   T_TYPE_ADDR         0x0F544
#define   T_IMPACT1_ADDR      0x0F546
#define   T_IMPACT2_ADDR      0x0F548
#define   T_IMPACT3_ADDR      0x0F54A
//Zone mémoire (caractéristiques de la cible + autres) */
#define   MEM_END_ADDR      0x0FFFF
Then is the application code (...)
At the end of my code I initialize the values that the memory should contain at the location defined above:
// On réserve de la place pour mémoriser des données (dans la mémoire flash car ces données
// ne vont changer que très rarement...)
#ORG T_NUM_ADDR,MEM_END_ADDR
#ROM T_NUM_ADDR = {TARGET_NUM}
#ROM T_CANAL_ADDR = {TARGET_CANAL}
#ROM T_TYPE_ADDR = {TARGET_TYPE}
#ROM T_IMPACT1_ADDR = {TARGET_IMPACT1}
#ROM T_IMPACT2_ADDR = {TARGET_IMPACT2}
#ROM T_IMPACT3_ADDR = {TARGET_IMPACT3}
The problem is that when I use the #fill_rom statement, these values will be overwritten by FFh in the Hex file. With #fill_rom commented out, the hex file contains the right values at the right address
I use Ver. 3.228
