pin to var assign
lsis
pin to var assign
PostPosted: Mon Jan 16, 2006 4:32 am     Reply with quote
HOW CAN ASSIGN PINS TO VARIABLE LIKE (PIN_C0, PIN_D3, PIN_B2 .....) VAR(INT16 VARNAME).
CAN I CHANGE THE VALUE OF VARIABLE TO HAVE DIRECT CHANGE ON PINS ?
PICoHolic
PostPosted: Mon Jan 16, 2006 4:52 am     Reply with quote
You could use structures. A good example is in 'lcd.c' (in 'drivers' folder)
Wink
PINS ASSIGN
PostPosted: Mon Jan 16, 2006 5:05 pm     Reply with quote
Thank's but how can assign pins from diferent ports in a structure?
PostPosted: Mon Jan 16, 2006 6:12 pm     Reply with quote
You should tell us what your overall goal is.
I'm not exactly sure what you want. So it's possible that
my post near the end of the following thread may help.
http://www.ccsinfo.com/forum/viewtopic.php?t=18949
It shows how to create a function which can set various
port bits, when you pass a byte parameter to the function.
LSIS
PostPosted: Mon Jan 16, 2006 6:36 pm     Reply with quote
Thank's.
