Port code from 18F4550 to 18F2455 problem
jspencer
PostPosted: Fri Jan 13, 2006 5:49 pm     Reply with quote
I have my current program working on the 18F4550 (CCS USB DEV KIT) and once I changed the fuses and setup for the 18F2455 (My hardware) it won't initialize or enumerate. Is there something obvious that I am missing? This is just a little test program to figure out what is going on.
#include <18F2455.h>
#device adc=8
#FUSES NOWDT                  //No Watch Dog Timer
#FUSES WDT128                 //Watch Dog Timer uses 1:128 Postscale
#FUSES HS                     //High speed Osc (> 4mhz)
#FUSES NOPROTECT              //Code not protected from reading
#FUSES NOBROWNOUT             //No brownout reset
#FUSES BORV20                 //Brownout reset at 2.0V
#FUSES PUT                    //Power Up Timer
#FUSES NOCPD                  //No EE protection
#FUSES NOSTVREN               //Stack full/underflow will not cause reset
#FUSES NODEBUG                //No Debug mode for ICD
#FUSES NOLVP                  //No low voltage prgming, B3(PIC16) or B5(PIC18) used for I/O
#FUSES NOWRT                  //Program memory not write protected
#FUSES NOWRTD                 //Data EEPROM not write protected
#FUSES NOIESO                 //Internal External Switch Over mode disabled
#FUSES FCMEN                  //Fail-safe clock monitor enabled
#FUSES NOPBADEN               //PORTB pins are configured as digital I/O on RESET
#FUSES NOWRTC                 //configuration not registers write protected
#FUSES NOWRTB                 //Boot block not write protected
#FUSES NOEBTR                 //Memory not protected from table reads
#FUSES NOEBTRB                //Boot block not protected from table reads
#FUSES NOCPB                  //No Boot Block code protection
#FUSES NOLPT1OSC              //Timer1 configured for higher power operation
#FUSES NOMCLR                 //Master Clear pin used for I/O
#FUSES NOXINST                //Extended set extension and Indexed Addressing mode disabled (Legacy mode)
#FUSES PLL1                   //No PLL PreScaler
#use delay (clock=20000000)
#define GREEN_LED    PIN_A0
#define YELLOW_LED   PIN_A1
#define I2C_SCL      PIN_C1
#define I2C_SDA      PIN_C0
#define LED_ON       output_low
#define LED_OFF      output_high
 * USB Definitions & includes
#define USB_EP1_TX_ENABLE USB_ENABLE_INTERRUPT
#define USB_EP1_TX_SIZE 8
#define USB_EP1_RX_ENABLE USB_ENABLE_INTERRUPT
#define USB_EP1_RX_SIZE 16
#define OUTPUT_REPORT_SIZE USB_EP1_TX_SIZE
#include <pic18_usb.h>
#include "usb_desc_hid.h"  // the local modified version
#include <usb.c>
void check_usb(void) {
   if(!usb_enumerated()) {
      LED_ON(YELLOW_LED);
      LED_OFF(GREEN_LED);
      while(!usb_enumerated()) {}
   LED_OFF(YELLOW_LED);
void main() {
   setup_spi(FALSE);
   setup_wdt(WDT_OFF);
   setup_timer_0(RTCC_INTERNAL);
   setup_timer_1(T1_DISABLED);
   setup_vref(FALSE);
   setup_low_volt_detect(FALSE);
   setup_oscillator(False);
   while (TRUE) {
      usb_init();
      check_usb();
      LED_ON(GREEN_LED);
      LED_ON(YELLOW_LED);
      LED_OFF(GREEN_LED);
****** usb_desc_hid.h  file that has been modified for project ******
#IFNDEF __USB_DESCRIPTORS__
#DEFINE __USB_DESCRIPTORS__
#include <usb.h>
   ///  HID Report.  Tells HID driver how to handle and deal with
   ///  received data.  HID Reports can be extremely complex,
   ///  see HID specifcation for help on writing your own.
   ///  CCS example uses a vendor specified usage, that sends and
   ///  receives 2 absolute bytes ranging from 0 to 0xFF.
   const char USB_CLASS_SPECIFIC_DESC[] = {
      6, 0, 255,    // Usage Page = Vendor Defined
      9, 1,            // Usage = IO device
      0xa1, 1,       // Collection = Application
      0x19, 1,        // Usage minimum
      0x29, 8,        // Usage maximum
      0x15, 0x80,        // Logical minimum (-128)
      0x25, 0x7F,        // Logical maximum (127)
      0x75, 8,        // Report size = 8 (bits)
      0x95, 2,        // Report count = 16 bits (2 bytes)  SDM CHange from 2
      0x81, 2,        // Input (Data, Var, Abs)
      0x95, 16,        // Report count = 16 bits (2 bytes)
      0x91, 2,        // Output (Data, Var, Abs)
      0xc0            // End Collection
   //if a class has an extra descriptor not part of the config descriptor,
   // this lookup table defines where to look for it in the const
   // USB_CLASS_SPECIFIC_DESC[] array.
   //first element is the config number (if your device has more than one config)
   //second element is which interface number
   //set element to 0xFFFF if this config/interface combo doesn't exist
   const int16 USB_CLASS_SPECIFIC_DESC_LOOKUP[USB_NUM_CONFIGURATIONS][1] =
   //config 1
      //interface 0
         0
   // this lookup table defines the size of that descriptor.
   const int16 USB_CLASS_SPECIFIC_DESC_LOOKUP_SIZE[USB_NUM_CONFIGURATIONS][1] =
   //config 1
      //interface 0
         32
///   start config descriptor
///   right now we only support one configuration descriptor.
///   the config, interface, class, and endpoint goes into this array.
   #DEFINE USB_TOTAL_CONFIG_LEN      41  //config+interface+class+endpoint+endpoint (2 endpoints)
   const char USB_CONFIG_DESC[] = {
   //IN ORDER TO COMPLY WITH WINDOWS HOSTS, THE ORDER OF THIS ARRAY MUST BE:
      //    config(s)
      //    interface(s)
      //    class(es)
      //    endpoint(s)
   //config_descriptor for config index 1
         USB_DESC_CONFIG_LEN, //length of descriptor size          ==1
         USB_DESC_CONFIG_TYPE, //constant CONFIGURATION (CONFIGURATION 0x02)     ==2
         USB_TOTAL_CONFIG_LEN,0, //size of all data returned for this config      ==3,4
         1, //number of interfaces this device supports       ==5
         0x01, //identifier for this configuration.  (IF we had more than one configurations)      ==6
         0x00, //index of string descriptor for this configuration      ==7
         0xC0, //bit 6=1 if self powered, bit 5=1 if supports remote wakeup (we don't), bits 0-4 unused and bit7=1         ==8
         0x32, //maximum bus power required (maximum milliamperes/2)  (0x32 = 100mA)
   //interface descriptor 1
         USB_DESC_INTERFACE_LEN, //length of descriptor      =10
         USB_DESC_INTERFACE_TYPE, //constant INTERFACE (INTERFACE 0x04)       =11
         0x00, //number defining this interface (IF we had more than one interface)    ==12
         0x00, //alternate setting     ==13
         2, //number of endpoins, except 0 (pic167xx has 3, but we dont have to use all).       ==14
         0x03, //class code, 03 = HID     ==15
         0x00, //subclass code //boot     ==16
         0x00, //protocol code      ==17
         0x00, //index of string descriptor for interface      ==18
   //class descriptor 1  (HID)
         USB_DESC_CLASS_LEN, //length of descriptor    ==19
         USB_DESC_CLASS_TYPE, //dscriptor type (0x21 == HID)      ==20
         0x00,0x01, //hid class release number (1.0) (try 1.10)      ==21,22
         0x00, //localized country code (0 = none)       ==23
         0x01, //number of hid class descrptors that follow (1)      ==24
         0x22, //report descriptor type (0x22 == HID)                ==25
         USB_CLASS_SPECIFIC_DESC_LOOKUP_SIZE[0][0], 0x00, //length of report descriptor            ==26,27
   //endpoint descriptor
         USB_DESC_ENDPOINT_LEN, //length of descriptor                   ==28
         USB_DESC_ENDPOINT_TYPE, //constant ENDPOINT (ENDPOINT 0x05)          ==29
         0x81, //endpoint number and direction (0x81 = EP1 IN)       ==30
         0x03, //transfer type supported (0x03 is interrupt)         ==31
         USB_EP1_TX_SIZE,0x00, //maximum packet size supported                  ==32,33
         250,  //polling interval, in ms.  (cant be smaller than 10)      ==34
         USB_DESC_ENDPOINT_LEN, //length of descriptor                   ==35
         USB_DESC_ENDPOINT_TYPE, //constant ENDPOINT (ENDPOINT 0x05)          ==36
         0x01, //endpoint number and direction (0x01 = EP1 OUT)      ==37
         0x03, //transfer type supported (0x03 is interrupt)         ==38
         USB_EP1_RX_SIZE,0x00, //maximum packet size supported                  ==39,40
         10 //polling interval, in ms.  (cant be smaller than 10)    ==41
   //****** BEGIN CONFIG DESCRIPTOR LOOKUP TABLES ********
   //since we can't make pointers to constants in certain pic16s, this is an offset table to find
   //  a specific descriptor in the above table.
   //NOTE: DO TO A LIMITATION OF THE CCS CODE, ALL HID INTERFACES MUST START AT 0 AND BE SEQUENTIAL
   //      FOR EXAMPLE, IF YOU HAVE 2 HID INTERFACES THEY MUST BE INTERFACE 0 AND INTERFACE 1
   #define USB_NUM_HID_INTERFACES   1
   //the maximum number of interfaces seen on any config
   //for example, if config 1 has 1 interface and config 2 has 2 interfaces you must define this as 2
   #define USB_MAX_NUM_INTERFACES   1
   //define how many interfaces there are per config.  [0] is the first config, etc.
   const char USB_NUM_INTERFACES[USB_NUM_CONFIGURATIONS]={1};
   //define where to find class descriptors
   //first dimension is the config number
   //second dimension specifies which interface
   //last dimension specifies which class in this interface to get, but most will only have 1 class per interface
   //if a class descriptor is not valid, set the value to 0xFFFF
   const int16 USB_CLASS_DESCRIPTORS[USB_NUM_CONFIGURATIONS][1][1]=
   //config 1
      //interface 0
         //class 1
         18
   #if (sizeof(USB_CONFIG_DESC) != USB_TOTAL_CONFIG_LEN)
      #error USB_TOTAL_CONFIG_LEN not defined correctly
   #endif
///   start device descriptors
   const char USB_DEVICE_DESC[USB_DESC_DEVICE_LEN] ={
      //starts of with device configuration. only one possible
         USB_DESC_DEVICE_LEN, //the length of this report   ==1
         0x01, //the constant DEVICE (DEVICE 0x01)  ==2
         0x10,0x01, //usb version in bcd (pic167xx is 1.1) ==3,4
         0x00, //class code ==5
         0x00, //subclass code ==6
         0x00, //protocol code ==7
         USB_MAX_EP0_PACKET_LENGTH, //max packet size for endpoint 0. (SLOW SPEED SPECIFIES 8) ==8
         0x61,0x04, //vendor id (0x04D8 is Microchip, or is it 0x0461 ??)
         0x20,0x00, //product id   ==11,12  //don't use ffff says usb-by-example guy.  oops
         0x00,0x01, //device release number  ==13,14
         0x01, //index of string description of manufacturer. therefore we point to string_1 array (see below)  ==15
         0x02, //index of string descriptor of the product  ==16
         0x00, //index of string descriptor of serial number  ==17
         USB_NUM_CONFIGURATIONS  //number of possible configurations  ==18
///   start string descriptors
///   String 0 is a special language string, and must be defined.  People in U.S.A. can leave this alone.
///   You must define the length else get_next_string_character() will not see the string
///   Current code only supports 10 strings (0 thru 9)
//the offset of the starting location of each string.  offset[0] is the start of string 0, offset[1] is the start of string 1, etc.
char USB_STRING_DESC_OFFSET[]={0,4,12};
char const USB_STRING_DESC[]={
   //string 0
         4, //length of string index
         USB_DESC_STRING_TYPE, //descriptor type 0x03 (STRING)
         0x09,0x04,   //Microsoft Defined for US-English
   //string 1
         8, //length of string index
         'C',0,
         'C',0,
         'S',0,
   //string 2
         26, //length of string index
         'C',0,
         'C',0,
         'S',0,
         ' ',0,
         'H',0,
         'I',0,
         'D',0,
         ' ',0,
         'D',0,
         'e',0,
         'm',0,
         'o',0
#ENDIF
Darren Rook
PostPosted: Fri Jan 13, 2006 10:32 pm     Reply with quote
No CPUDIV fuse?
Doesn't look like you're setting the internal 4MHz USB clock right (see CPUDIV fuse)
I came, I saw, I compiled.
jspencer
PostPosted: Sat Jan 14, 2006 8:09 am     Reply with quote
Thanks for looking at it Darren. As I was leaving work last night I thought that maybe I was leaving a fuse out or not setting something right as it is just the usb that is not working. I'll give it a try on Monday unless I sneak into the office this weekend.
James
jspencer
Solution found
PostPosted: Mon Jan 16, 2006 12:36 pm     Reply with quote
Thanks again Darren for the help. I got it functioning and the fuses ended up looking like this for reference.
#fuses HSPLL,NOWDT,NOPROTECT,NOLVP,NODEBUG,USBDIV,PLL5,CPUDIV1,VREGEN,NOMCLR
#use delay (clock=48000000)
