Unidentified Identifier: RS232_ERRORS
edhaslam
PostPosted: Fri Jan 13, 2006 7:50 am     Reply with quote
Hi all,
I've progressed onto learning about serial interupts and circular buffers and found a piece of code that checks the framing error bit of the rs232_error register, but when I compile the code I get the 'Unidentified Identifier' error message. The first part of the interupt routine is as follows:
#int_rda
void SerialInterrupt ( void )
char cChar;
    if ( RS232_ERRORS & 0x04 )  // get framing error bit from Rx status reg
        cRxErrorFlag = ON;
    cChar = getchar();       // get char from UART, clear any errors
etc...
Do I have to define/declare the use of the RS232_ERRORS register somewhere at the beginning of the code? Can someone point me to any information on how to access/use this register?
dyeatman
PostPosted: Fri Jan 13, 2006 10:31 am     Reply with quote
This has been discussed numerous times on this forum. I appreciate that you are trying to learn but please try searching the forum before asking a question to see if it has already been answered. Many times you will get much more information and example code as a bonus!
Take a look at the link below for your answer..
http://www.ccsinfo.com/forum/viewtopic.php?t=22876&highlight=rs232errors
Regards
edhaslam
PostPosted: Fri Jan 13, 2006 1:25 pm     Reply with quote
Regards
Believe me I have searched and searched and I never post until I am really stuck. I have been programming for some time now and am not a newbie, just new to this particular area.
I know this has been discussed many times before and I have read *both* of the threads that you have suggested prior to posting, but it still hasn't answered my question. All of the suggestions that have been offered in those threads haven't helped me.
Can you (or anyone else) point me to where the RS232_ERRORS is discussed in the manual or some other source?
BTW: I am using the latest version of the compiler. I can post the entire code if necessary.
PostPosted: Fri Jan 13, 2006 2:02 pm     Reply with quote
Are you using #case with RS232_ERRORS in upper case ?
That will cause the "undefined identifier error, because CCS
uses lower case for that symbol. See the symbol table below:
SYMBOL TABLE
  LABEL                             VALUE
PSP_DATA                          00000008
CCP_1_LOW                         00000015
CCP_1                             00000015
CCP_1_HIGH                        00000016
CCP_2_LOW                         0000001B
CCP_2                             0000001B
CCP_2_HIGH                        0000001C
rs232_errors                      00000020
main.c                            00000021
_RETURN_                          00000078
main                              00000004
#include <16F877.H>
#case // This will cause the "undefined identifier" error
char c;
c = RS232_ERRORS;
Humberto
PostPosted: Fri Jan 13, 2006 2:59 pm     Reply with quote
Well, this is not the only issue that is not clearly discussed in the manual nor in any source.
CCS Compiler has a lot of built-in functions whose generated object code is not visible to
the user.
Anyway I will try to clarify this issue. When you include the parameter ERRORS in the
pre-processor directive #use RS232(..) the compiler generate extra code to clear the
detected errors in the RCSTA register. The capability of detecting an error is a PIC feature,
not a compiler capability.
PIC microcontrollers with built in Serial Controller Interface has this feature
because its data recovery block operate at 16x times the baud rate so it can recover
enough info to detect unexpected levels detected in every single bit of the arraiving
character, namelly overrun errors.
Normally this is done in the ninth bit (normally the STOP bit for an 8 bit wide) the
compiler make a copy of the RCSTA (Receiver Status and Control Register)
in the variable rs232_errors and test the bit 1 (OERR) to determine if any error
occurred during the char reception, if any error occurred, set the enable bit CREN.
The action of the CREN bit is not trivial:
CREN: Continuous Receive Enable bit.
1= Enable continuous receive
0= Disable continuous receive
If you do not include the ERRORS parameter in the #use RS232(..) directive,
the ocurrence of the first error will clear the CREN and block the receiver.
Including ERRORS the compiler generate this extra code to handle the detected errors.
D <! .................... #use rs232(baud=9600,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8,errors)
D <! 00A0:  BTFSS  PIR1.5
D <! 00A2:  BRA    00A0
D <! 00A4:  MOVFF  RCSTA,rs232_errors
D <! 00A8:  MOVFF  RCREG,01
D <! 00AC:  BTFSS  rs232_errors.1
D <! 00AE:  BRA    00B4
D <! 00B0:  BCF    RCSTA.4
D <! 00B2:  BSF    RCSTA.4
D <! 00B4:  NOP
D <! 00B6:  GOTO   00BC (RETURN)
Humberto
PostPosted: Fri Jan 13, 2006 3:55 pm     Reply with quote
Generally, CREN, is not cleared by an error.
The error flags themselves 'block' reception, and it is the act of clearing CREN, that clears the errors. Hence the bit has to be cleared, and then reset.
It may just be 'worth' being aware of this difference, if handling any of this yourself.
edhaslam
PostPosted: Sat Jan 14, 2006 10:47 am     Reply with quote
Hi Guys,
This is all very useful, constructive information, just what I needed - many thanks.
I haven't tried using the #case pre-processor yet but I am using ERRORS in #use rs-232. I did try rs232_errors in uppper and lower case but no difference there.
Here is the piece of code that I have been learning from. It's for a GPS compass. Unfortunately I can't remember who wrote it, so I can't credit them. They did publish it on the web for people to use, so I feel it's ok to post the whole thing here. If you do recognise the code, then an eplanation of the use of the rs232_errors variable in the code would be very useful (or anyone else who can comment on it!).
compass.c
This program receives NMEA-0183 heading data from a GPS
and displays it on an array of LEDs.
                   +5
                    14
               |          |-6----- N
    ~SerIn --7-|          |-9----- NE
               |          |-10---- E
       XTAL-15-|  16F628  |-11---- SE
       XTAL-16-|          |-2----- S
       CLK -12-|          |-1----- SW
      DATA -13-|          |-18---- W
      MCLR --4-|          |-17---- NW
                    5
                    |        CLK, DATA, MCLR are optional programming port.
                   Gnd
#case
#include <16F628.h>
#include <jonsinc.h>
#define EOF             0x00
#define COMMA           ','
#define CR              13
#define SPACE           ' '
#define PERIOD          '.'
#define DOLLAR          '$'
#define NULL            0
#define GPRMC_CODE      75
#define RX_BUFFER_SIZE  70
#define LED_N           PIN_B0
#define LED_NE          PIN_B3
#define LED_E           PIN_B4
#define LED_SE          PIN_B5
#define LED_S           PIN_A3
#define LED_SW          PIN_A2
#define LED_W           PIN_A1
#define LED_NW          PIN_A0
#define ROTATE_MS       30
#define RX_IN           PIN_B1
#define PROG_CLK        PIN_B6
#define PROG_DAT        PIN_B6
#define PROG_MCLR       PIN_A5
#separate char GetField ( void );
#separate void AllOff ( void );
#separate void GetHeading ( void );
#separate void DisplayHeading ( void );
#separate long TrueToMag ( long iH );
#separate long FieldFiveToLong ( void );
#separate void InitRxBuffer ( char cCode );
#separate char GetRxChar ( void );
#fuses HS, NOPROTECT, PUT, NOWDT, BROWNOUT, NOLVP, NOCPD, NOMCLR
#use standard_io ( A )
#use standard_io ( B )
#use delay ( clock = 8000000 )
#use rs232 ( baud=4800, xmit=PIN_B2, rcv=PIN_B1, ERRORS )    // XMIT must be assigned to enable hardward USART
static char cC [ 10 ];      // local buffer
static char cTimeOut;
static char cRxBuffer [ RX_BUFFER_SIZE ];    // Fifo
static char cRxByteCnt;         // Number of bytes in the recv fifo
static char *cRxBufferWritePtr;    // Pointers for the Rx buffer
static char *cRxBufferReadPtr;
static char cRxIsrState, cRxMsgTypeReceived, cRxMsgTypeDesired;
static char cRxMsgReady, cReceiveFlag;
static long iVar, iHdg;
static char cRxErrorFlag, cVarDir, cError;
#int_rtcc
void Timer0Interrupt ( void )
    // Gets here every 16.52mS
    // Handles data timeout
    if ( cTimeOut != 0 )
        cTimeOut--;
#int_rda
    Reads incoming data from the USART and puts in in a rolling buffer
    ( but in this application, it should never roll.)
    If the buffer is full, this routine just discards the received byte.
    Not checking the LRC byte at the end of the NMEA-0183 sentence.
    char cChar;
    if ( rs232_errors & 0x04 )  // get framing error bit from Rx status reg
        cRxErrorFlag = ON;
    if ( cRxByteCnt == RX_BUFFER_SIZE ) // is recv fifo full ???
        goto done;
    switch ( cRxIsrState )
        case 0:
            if ( cChar == DOLLAR )  // if start of NMEA0183 message
                cRxByteCnt = 0;     // reset byte count
                cReceiveFlag = OFF;     // default to off
                cRxMsgTypeReceived = NULL;  // set hashed value to null
                cRxIsrState++;                 // next state
        case 1:                           // five type characters to obtain
        case 2:
        case 3:
        case 4:
        case 5:
            cRxMsgTypeReceived ^= cChar;      // hash in msg type
            if ( cRxIsrState++ == 5 )        // if time to check message type
                if ( cRxMsgTypeReceived == cRxMsgTypeDesired )  // if good
                    cReceiveFlag = YES;            // enable receiving
                    cRxBufferWritePtr = cRxBuffer;    // reset to beginning of buffer
                else                    // don't want this message
                    cRxIsrState = 0;    // reset to look for next msg
        case 6:
            /* Case 6 skips the comma character following msg type */
            cRxIsrState++;
        default:                          // remainder of characters
            if ( cReceiveFlag == YES )        // if this message is wanted
                *cRxBufferWritePtr = cChar;     // put char in fifo
                cRxBufferWritePtr++;            // increment pointer
                if ( cRxBufferWritePtr == ( cRxBuffer + RX_BUFFER_SIZE ) ) // pointer past end ?
                    cRxBufferWritePtr = cRxBuffer;      // set pointer to start of fifo
                cRxByteCnt++;              // Increment byte count
                if ( cChar == CR )
                    cRxMsgReady = YES;         // signal that message is ready
                    cReceiveFlag = NO;      // no more receive
    done:;               // label
void main ( void )
    char cX;
    /* INITIALIZE */
    output_float ( RX_IN );             // ensure Rx input is HiZ
    output_float ( PROG_CLK );
    output_float ( PROG_DAT );
    output_float ( PROG_MCLR );
    // SETUP TIMER 0
    // Need 8-bit Timer0 to roll over every 13mS, approximately.
    // Roll time = 256 * 1 / ( clock_freq / prescaler setting / 4 )
    setup_counters ( RTCC_INTERNAL, RTCC_DIV_128 );   // ~13mS timer wrap
    /* INTERRUPTS */
    enable_interrupts ( INT_TIMER1 );   // enable Timer1 interrupt
    enable_interrupts ( INT_RTCC );     // enable Timer0 interrupt
    enable_interrupts ( INT_RDA );      // enable serial interrupt
    enable_interrupts ( GLOBAL );       // enable all interrupts
    /* VARIABLES */
    iVar = NULL;                        // default, no variation yet
    cVarDir = SPACE;                    // default, no variation yet
    cRxErrorFlag = OFF;
    for ( cX = 0; cX < 5; cX++ )
        output_low ( LED_NW ); output_high ( LED_N ); delay_ms ( ROTATE_MS );
        output_low ( LED_N ); output_high ( LED_NE ); delay_ms ( ROTATE_MS );
        output_low ( LED_NE ); output_high ( LED_E ); delay_ms ( ROTATE_MS );
        output_low ( LED_E ); output_high ( LED_SE ); delay_ms ( ROTATE_MS );
        output_low ( LED_SE ); output_high ( LED_S ); delay_ms ( ROTATE_MS );
        output_low ( LED_S ); output_high ( LED_SW ); delay_ms ( ROTATE_MS );
        output_low ( LED_SW ); output_high ( LED_W ); delay_ms ( ROTATE_MS );
        output_low ( LED_W ); output_high ( LED_NW ); delay_ms ( ROTATE_MS );
    /* MAIN LOOP */
    while ( TRUE )
        cTimeOut = 242;                 // 242 * 0.0165mS = 4 seconds
        cRxErrorFlag = OFF;             // default to off
        cError = OFF;
        InitRxBuffer( GPRMC_CODE );     // set code and turn on serial interrupt
        while ( ( cRxMsgReady == NO ) && ( cTimeOut != 0 ) );   // wait for RMC sentence
        //disable_interrupts ( INT_RDA ); // ignore rest of messages
        if ( ( cTimeOut != 0 ) && ( cRxErrorFlag == OFF ) )   // if no errors
            GetHeading();               // get heading and variation
            AllOff();                   // turn all LED's off
            if ( cError == OFF )
                DisplayHeading();           // display heading
            AllOff();                   // error, data timeout or framing error
        //enable_interrupts ( INT_RDA );  // enable Rx again
    GetField();                     // skip UTC
    GetField();                     // A = OK, V = warning
    if ( cC [ 0 ] == 'A' )          // if valid
        GetField();                 // skip LAT
        GetField();                 // skip N/S
        GetField();                 // skip LON
        GetField();                 // skip E/W
        GetField();                 // skip SPD
        GetField();                 // get HDG
        iHdg = FieldFiveToLong();   // convert
        GetField();                 // skip FIX DATE
        GetField();                 // get MAG VAR
        iVar = FieldFiveToLong();   // convert
        GetField();                 // get EW variation direction
        cVarDir = cC [ 0 ];         // save variation direction
        iHdg = TrueToMag ( iHdg );  // factor variation into heading
        cError = ON;                // error, corrupted data from satellite
    if ( ( ( iHdg > 337 ) && ( iHdg <= 359 ) ) || ( ( iHdg >= 0 ) && ( iHdg <= 23 ) ) )     // N
    if ( ( iHdg > 23 ) && ( iHdg <= 68 ) )       // NE
    if ( ( iHdg > 68 ) && ( iHdg <= 113 ) )      // E
    if ( ( iHdg > 113 ) && ( iHdg <= 158 ) )     // SE
    if ( ( iHdg > 158 ) && ( iHdg <= 203 ) )     // S
    if ( ( iHdg > 203 ) && ( iHdg <= 248 ) )     // SW
    if ( ( iHdg > 248 ) && ( iHdg <= 293 ) )     // W
    if ( ( iHdg > 293 ) && ( iHdg <= 337 ) )     // NW
    /* Converts ABC.D to long ABC, rounds fraction part up or down */
    long iX;
    iX = 100 * ( long ) ( cC [ 0 ] - 0x30 );
    iX += 10 * ( long ) ( cC [ 1 ] - 0x30 );
    iX += ( long ) ( cC [ 2 ] - 0x30 );
    if ( ( cC [ 3 ] == PERIOD ) && ( cC [ 4 ] >= '5' ) )
        iX++;           // round up
    return ( iX );
    /* Magnetic variation information comes from the RMC sentence */
    if ( cVarDir == 'W' )
        iH += iVar;
        if ( iH >= iVar )
            iH -= iVar;     // OK as-is
            iH = iH + 360 - iVar;   // correct for below zero
    if ( iH >= 360 )
        iH -= 360;
    return ( iH );
    char cX, cIndex;
    // Get next field from cRxBuffer and put in cC buffer.
    cX = NULL;
    cIndex = 0;
    while ( cTimeOut != 0 )
        cX = GetRxChar();
        if ( ( cX == COMMA ) || ( cX == CR ) )
        cC [ cIndex++ ] = cX;
    cC [ cIndex ] = EOF;
    return ( cIndex );         // return number of characters in field
/* RS232 FUNCTIONS ================================================== */
    cRxBufferWritePtr = cRxBuffer;      // point to beginning of buffer
    cRxBufferReadPtr = cRxBuffer;
    cRxByteCnt = 0;
    cRxIsrState = 0;
    cRxMsgReady = NO;
    cRxMsgTypeDesired = cCode;
    // Get the next available byte in the recv fifo.
    // Call this function ONLY if the recv fifo contains data.
    char cValue;
    cValue = 0;
    if ( cRxByteCnt > 0 )       // For safety, check if there is any data
        cValue = *cRxBufferReadPtr++;     // Read byte from fifo
        if ( cRxBufferReadPtr == ( cRxBuffer + RX_BUFFER_SIZE ) ) // Did tail ptr wrap ?
            cRxBufferReadPtr = cRxBuffer;    // If so, reset it to start of buffer
        cRxByteCnt--; // Decrement byte count
    return ( cValue );
Cheers,
Ed
Humberto
PostPosted: Sat Jan 14, 2006 11:44 am     Reply with quote
This code must be credited to Jon Fick (Westford MicroSystems).
I compiled the code as is, except that I add the directive for a pointer of 16 bit as follow:
#case
#include <16F628.H>
#device *=16
Following I post the code involved with rs232_errors:
.................... #use rs232 ( baud=4800, xmit=PIN_B2, rcv=PIN_B1, ERRORS )    // XMIT must be assigned to enable hardward USART
0040:  BTFSS  PIR1.5
0041:  GOTO   040
0042:  MOVF   RCSTA,W
0043:  MOVWF  rs232_errors
0044:  MOVF   RCREG,W
0045:  MOVWF  @78
0046:  BTFSS  rs232_errors.1
0047:  GOTO   04A
0048:  BCF    RCSTA.4
0049:  BSF    RCSTA.4
004A:  NOP
004B:  GOTO   051 (RETURN)
You will see clearly:
0042: MOVF RCSTA,W
where the compiler make a copy of RCSTA.
Then in the INT_RDA, Jon makes -by hand- a test of bit 2 (FERR) of the copy of RCSTA
looking for a frame error:
if ( rs232_errors & 0x04 ) or
BTFSS rs232_errors.2
Note that for test a bit he uses the same variable that CCS does internally,
just for saving RAM, wich is a good practice. Otherwise he would create a new one
and this would not make sense.
....................     if ( rs232_errors & 0x04 )  // get framing error bit from Rx status reg
004C:  BTFSS  29.2
004D:  GOTO   050
....................         cRxErrorFlag = ON;
004E:  MOVLW  01
004F:  MOVWF  cRxErrorFlag
The sym list shows the name of the variable living at address 029.
027     @INTERRUPT_AREA
028     @INTERRUPT_AREA
029     rs232_errors
02A-033 cC
034     cTimeOut
035     cRxByteCnt
Humberto
edhaslam
PostPosted: Sun Jan 15, 2006 4:02 pm     Reply with quote
Hi Humberto,
#device *=16 did the trick - can't believe I didn't think of that. Program runs fine now. I tried converting it to run on an 'F877A using a MAX232 and it's UART, but I can't get it to display the heading when I introduce a GPS signal. I know the GPS signal is valid and that the com port/coms connections work as they have been proven before. Is there anything I could be doing wrong when changing over to an F877A? Code changes:
#case
#include <16F877A.h>
#device *=16
#define EOF             0x00
#define COMMA           ','
#define CR              13
#define SPACE           ' '
#define PERIOD          '.'
#define DOLLAR          '$'
#define NULL            0
#define LED_N           PIN_D0
#define LED_NE          PIN_D1
#define LED_E           PIN_D2
#define LED_SE          PIN_D3
#define LED_S           PIN_D4
#define LED_SW          PIN_D5
#define LED_W           PIN_D6
#define LED_NW          PIN_D7
//#define RX_IN           PIN_B1
//#define PROG_CLK        PIN_B6
//#define PROG_DAT        PIN_B6
//#define PROG_MCLR       PIN_A5
#fuses HS, NOPROTECT, PUT, NOWDT, BROWNOUT, NOLVP, NOCPD //NOMCLR
#use rs232 ( baud=4800, xmit=PIN_C6, rcv=PIN_C7, ERRORS )    // XMIT must be assigned to enable hardward USART
Humberto
PostPosted: Mon Jan 16, 2006 9:01 am     Reply with quote
Do you mean that the program compiled succesfully or the whole hardware + firmware
is running OK receiving GPS string and showing heading info?
I can't see why it doesn't work in the 'F877A'. Did you make a simple test in the 'F877A' hardware
to be sure that it is properly wired and the oscillator working ?
Humberto
edhaslam
PostPosted: Mon Jan 16, 2006 9:35 am     Reply with quote
It compiles and runs, but the program doesn't display the heading. When I send a gps stream of data, the D0 LED lights up. And when I stop the GPS signal, D0 goes out. That's it.
I know the harware is fine as I have it running on a dev board that I have been using for a long time now. Also, when the program runs you can see the 'direction' LEDs scroll as per this bit of code:
Humberto
PostPosted: Mon Jan 16, 2006 10:08 am     Reply with quote
edhaslam,
The for loop is a piece of code before the main() just to see that the program had started. It doesn't do anymore.
I could start debugging the INT_RDA handler just to watch if something is arraiving. For example:
#int_rda
    char cChar;
        cRxErrorFlag = ON;
    if(cChar == DOLLAR )  // if start of NMEA0183 message
       output_high ( LED_n ); // Just to see if the first char of the GPS stream ('$') had arrived
I can't help you anymore that in code because I didn't implement this code nor has
a GPS receiver to play with. May be somebody that had worked with this can help you.
Keep well,
Humberto
edhaslam
PostPosted: Mon Jan 16, 2006 1:42 pm     Reply with quote
Humberto wrote:
edhaslam,
#int_rda
    char cChar;
        cRxErrorFlag = ON;
Keep well,
Humberto
Hi Humberto,
Many thanks - I'll try the RDA debugging code you suggested. I understand that it's hard to debug without seeing the hardware.
Many thanks again,
Ed
