		| Author | Message |
		| sonicdeejay
				| Trying to generat 2 PWM in port C using PIC18F2431 |
				|  Posted: Thu Jan 12, 2006 6:28 am |   |
				| My code is as followed....
 and I can't measure any square wave in my oscilloscope,,,
 #include <18F2331.h>
 #device adc=8 //Where x is the number of bits read_adc() should return
 #use delay(clock = 4000000)
 //#use delay(clock=20000000)
 #fuses XT,NOWDT,WDT128,HS, NOPROTECT, IESO, BROWNOUT, BORV27, NOPUT, NOCPD, STVREN, NODEBUG, LVP, NOWRT, NOWRTD, FCMEN, NOWINEN, T1LOWPOWER, HPOL_HIGH, NOWRTC, NOWRTB, NOEBTR, NOEBTRB, NOCPB, LPOL_HIGH, PWMPIN, NOMCLR, FLTAC1, SSP_RC
 //setup_adc_ports(NO_ANALOGS|VSS_VDD);
 setup_spi(FALSE);
 setup_wdt(WDT_ON);
 setup_timer_0(RTCC_INTERNAL);
 setup_timer_1(T1_DISABLED);
 SET_TRIS_A( 0x0F ); //Declare as Output
 //setup_adc_ports( RA0_ANALOG );
 //setup_adc( ADC_CLOCK_INTERNAL );
 //set_adc_channel( 0 );
 //int i, value, min, max;
 output_high(PIN_A0);
 output_low(PIN_A0);
 output_low(PIN_A0);
 //PWM test Drive
 output_low(PIN_C1); // Set CCP2 output low
 output_low(PIN_C2); // Set CCP1 output low
 setup_ccp1(CCP_PWM); // Configure CCP1 as a PWM
 setup_ccp2(CCP_PWM); // Configure CCP2 as a PWM
 setup_timer_2(T2_DIV_BY_16, 124, 1); // 500 Hz
 set_pwm1_duty(31); // 25% duty cycle on pin C2
 set_pwm2_duty(62); // 50% duty cycle on pin C1
		| PCM programmer
				|  Posted: Thu Jan 12, 2006 1:37 pm |   |
				| Make the changes shown in bold below:
  	  | Quote: |  	  | #fuses XT,NOWDT,WDT128,HS, NOPROTECT, IESO, BROWNOUT, BORV27, NOPUT, NOCPD, STVREN, NODEBUG, NOLVP, NOWRT, NOWRTD, FCMEN, NOWINEN, T1LOWPOWER, HPOL_HIGH, NOWRTC, NOWRTB, NOEBTR, NOEBTRB, NOCPB, LPOL_HIGH, PWMPIN, NOMCLR, FLTAC1, SSP_RC |
  	  | Quote: |  	  | void main() {
 setup_spi(FALSE);
 setup_wdt(WDT_ON);
 // while(1)    // Comment out these two lines.
 output_low(PIN_A0);
 output_low(PIN_A0);
 //PWM test Drive
 while(1);       // Add this line
 | You cannot post new topics in this forum You cannot reply to topics in this forum
