small question
hadeelqasaimeh
small question
PostPosted: Sat Jan 07, 2006 5:13 pm     Reply with quote
im sorry that im new with this compiler
just a queistion:
strcspn ()its supooesd to count of initial char in s1 not in s2,what dose this mean????
i try to print the result on lcd, but i have nothing,its supooesd to give integer isnt it???
her is the code
#include <16f874.h>
#include "lcd_kbd1.c"
#include <string.h>
#fuses XT,NOWDT,NOLVP
#use delay(clock=4000000)    //one instruction=1us
#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7,ERRORS)
static char RX[20],h,ptr,string1[20], string2[20],S1[10];
static int1 jj;
static int8 i;
int rink;
int1 res;
void main()  {
   LCD_Init ( );
   strcpy(string1,"abcdefg");
   strcpy(string2,"cdefg");
   res=strcspn  (s1, s2);
   LCD_PutCmd ( CLEAR_DISP );
   LCD_SetPosition ( LINE_16_1);
   printf(LCD_PutChar,"res=",res);
thank u
JBM
PostPosted: Sat Jan 07, 2006 9:14 pm     Reply with quote
One problem is that in your printf statement, you haven't told the compiler how to print out the contents of res. To treat res as an unsigned int8, use this:
   printf(LCD_PutChar,"res=%u",res);
I have a feeling string functions return a signed value, but the manual should tell you - mine isn't to hand. This should at least show something.
-JBM
hadeelqasaimeh
PostPosted: Sun Jan 08, 2006 3:58 am     Reply with quote
hi JBM
I did what u talled me,it gives me res=1 all the time and this also not right
i mean when i change the char the same result appear<res=1 all the time
what can i do now??? Confused Shocked
thanx
PostPosted: Sun Jan 08, 2006 4:04 am     Reply with quote
it gives me res=1 all the time.
Look closely at your code. What values can res hold ?
static int8 i;
int rink;
int1 res;
hadeelqasaimeh
PostPosted: Sun Jan 08, 2006 8:41 am     Reply with quote
oops,.....yes thats it!!!!
thank u Laughing
