modifying 24LC256 driver
EmbdFreak
PostPosted: Mon Jan 02, 2006 4:12 am     Reply with quote
hi,
I am using the 24lc256's driver file as a driver to my Atmel's 24c512.
would modifying the two #defines EEPROM_SIZE and EEPROM_ADDRESS be enough to use the 24256.c as the ATMEL24c512's driver.
Moreoever, plz also specify if only page writes (128bytes) are possible, cuz my observation is that writing smaller chunks (5-10 bytes) is no problem either, as the datasheet recommends
Comments welcome !
BTW I have a compiler version ver 3.203.
Regards,
EF
PostPosted: Mon Jan 02, 2006 1:03 pm     Reply with quote
The current version of the CCS compiler comes with a driver for the
24LC512. It's called 24512.C. The only change from 24256.C is
the eeprom size definition. In 24512.C, it is changed to this:
#define EEPROM_SIZE   65535
EmbdFreak
PostPosted: Thu Jan 05, 2006 5:56 am     Reply with quote
thanks for the help.
Actually in my application im just incrementing the variable address without having to care about the page write restriction. It seems its no problem until the end of the memory i.e 64k limit,for which id cater. Is my observation correct?
PostPosted: Thu Jan 05, 2006 3:26 pm     Reply with quote
The last two words are garbled. What is "id cater" ?
newguy
PostPosted: Thu Jan 05, 2006 3:49 pm     Reply with quote
I read that as "I'd cater to this feature/limitation."
EmbdFreak
PostPosted: Thu Jan 05, 2006 11:55 pm     Reply with quote
Smile Well, PCMProgrammer, Newguy guessed my hidden apostraphraphe right there ! Anyways heres a restatement with correct punctuation this time.
Can i fill up my memory simply by writing:
WRITE_EXT_EEPROM(address,value);
address++;
Id be writing a chunk of say 10 bytes every time calling the above code in a loop, without caring for any page writing. Moreover, ive observed it starts overriting from first location once its filled, acting as a circular buffer. Now am i correct ?? ( Umm..No punctuation mistake, here i suppose Smile )
PostPosted: Fri Jan 06, 2006 1:01 am     Reply with quote
If "address" is a 16-bit variable, when it reaches 0xFFFF and you
increment it one more time, it will wrap around to 0x0000.
However, because the EEPROM has a size of 65536 bytes, it's not
an even multiple of 10. So your record offsets would change each
time your address wrapped around. i.e., The offsets would not
stay at fixed values of 0, 10, 20, 30, etc. If you intend for the
address to wrap around, it would be better if you picked a record
size that is a power of 2, such as 8 or 16.
EmbdFreak
PostPosted: Fri Jan 06, 2006 4:32 am     Reply with quote
Thanks again. it ll surely help !
Regards,
EF
