time required for fast_io ports to switch between input and
Posted: Tue Jun 17, 2003 3:15 pm
Hi, I'm using PCM on a PIC16F877. I'm trying to get fast_io to work with port c.<p>
Does anyone know what the minimum time required to shift from output to input is? I am emulating a bidirectional bus.<p>
___________________________
Original Post ID: 144515334
Sherpa Doug Guest
Re: time required for fast_io ports to switch between input
Posted: Tue Jun 17, 2003 3:30 pm
:=Hi, I'm using PCM on a PIC16F877. I'm trying to get fast_io to work with port c.<p>
:=Does anyone know what the minimum time required to shift from output to input is? I am emulating a bidirectional bus.<p>
Probably about the time it takes for two opcodes or Xtal speed/8. It is just the time to write a new value to the tristate register. Write a trivial program, compile it and look at the list file.
Original Post ID: 144515336
