Different Checksum with different version of CCS ???
msstaf
PostPosted: Wed Jan 04, 2006 9:52 am     Reply with quote
Hy,
I actually work with 2 different version of CCS a 3.219 version and a 3.240 version in two different computer. When i compile the same project and the same file i haven't the same checksum and i haven't the same file.hex, file.cof, it's a big problem for me because i need to work with this two version. I check the option and it's seems to be the same, Someone have a solution please ???
( excuse for my bad english Laughing )
PostPosted: Wed Jan 04, 2006 10:12 am     Reply with quote
CCS will can change their library functions, and the start-up code
in main(), and the optimizations, and also do bug fixes.
Don't expect different compiler versions to make identical Hex files.
rwyoung
PostPosted: Wed Jan 04, 2006 10:13 am     Reply with quote
Well, they are producing different machine code. Changes in the compiler tend to do that. Things are fixed, improved or broken as the compiler version numbers change.
Compare the LST files from both and you will see the differences.
If you want the same checksum, use the same version of compiler every time but different machinecode will produce different checksums.
Rob Young
The Screw-Up Fairy may just visit you but he has crashed on my couch for the last month!
treitmey
PostPosted: Wed Jan 04, 2006 11:54 am     Reply with quote
If they produced the same hex code, they wouldn't be much of an update.
Wouldn't it be great to charge customers for an update and never change/fix the program. ((microsoxxx))
msstaf
PostPosted: Thu Jan 26, 2006 12:26 pm     Reply with quote
I install the same version of ccs and i find the same Checksum. THis is the only solution.
Thank for your answer.
