Fast 16x16 Multiply with 32-bit Result
itp
PostPosted: Mon Jan 02, 2006 9:24 am     Reply with quote
Hi all,
Any idea for Faster 16x16 Multiply with 32-bit Result in C
Regards
Itp
Re: Fast 16x16 Multiply with 32-bit Result
PostPosted: Tue Jan 03, 2006 5:35 am     Reply with quote
It helps if you tell us what your current situation is and how much faster you need it to be.
If you are using a PIC16 processor it helps to upgrade to a (pin compatible) PIC18 processor because of the 8-bit hardware multiplier in the PIC18.
Can you use a faster clock crystal? Most PIC18's can be clocked up to 40MHz.
www.piclist.com is a great source for alternative routines.
PostPosted: Tue Jan 03, 2006 10:36 am     Reply with quote
And of course, look at the _mul function....
