not exactly...what i meant is to get the current value instead of voltage...did u noe how??
or if its similar...can u tell me the formula to get the current input??
kender
Posted: Thu Dec 29, 2005 1:11 am
connect your current output to ground through a resistor and measure the voltage on the high sideof the resistor with the A/D. V=IR.
SherpaDoug
In very basic terms you need the current to run through a shunt resistor which produces a very small voltage signal. Then you need to amplify the voltage to something the PIC A/D can use. You have to be careful what type of amplifier you use because the voltage to be measured is so close to the amplifier power supply voltage. _________________ The search for better is endless. Instead simply find very good and get the job done.
