		| View previous topic :: View next topic   |
			Harrison P Guest
				| External Eeprom 24LC01B with 16F877 and WDT enabled |
				 Posted: Mon Jun 16, 2003 12:16 am     |
				<font face="Courier New" size=-1>Hello Everyone,
I am having some major troubles with the 24LC01B serial eeprom.  I enabled WDT because the program that I am using requires wdt to work correctly.  I am using the device driver 2401.c include file.  I have changed the
#define EEPROM_SDA  PIN_B6
#define EEPROM_SCL  PIN_B7
to match my program settings.
Here is my setup:
PCM 3.102
24LC01B:
Pin 1 Floating
Pin 2 Floating
Pin 3 Floating
Pin 4 Gnd
Pin 5 Data - PIC B6 - 10k pullup
Pin 6 Clk - PIC B7
Pin 7 WP - Gnd
Pin 8 Vcc
The PIC will read in random data if I do not have the eeprom inserted in its circuit.  With the eeprom the PIC keeps on reseting.  I do a restart_wdt(); before the read_ext_eeprom(address).
Any help will be highly appreciated.  Sorry if my question is hard to follow.  I am 15 and it is hard to think correctly after having the eeprom problem for 2 days.
<blink><marquee>Please Help :(</marquee></blink>
Harrison Pham</font>
___________________________
	Original Post ID: 144515274 |
				| Re: External Eeprom 24LC01B with 16F877 and WDT enabled |
				 Posted: Mon Jun 16, 2003 2:42 pm     |
				:=I am having some major troubles with the 24LC01B serial eeprom.  I enabled WDT because the program that I am using requires wdt to work correctly.  I am using the device driver 2401.c include file.  I have changed the
:=#define EEPROM_SDA  PIN_B6
:=#define EEPROM_SCL  PIN_B7
:=to match my program settings.
So that means you are using pins B6 and B7 ?
Are you using an ICD debugger ?
Those pins are used by the ICD.
Also, have you tested your program without the WDT ?
Does it work ?
:=Here is my setup:
:=PCM 3.102
:=24LC01B:
:=Pin 1 Floating
:=Pin 2 Floating
:=Pin 3 Floating
:=Pin 4 Gnd
:=Pin 5 Data - PIC B6 - 10k pullup
I always put a pull-up on the clock pin.
According to the Microchip appnote, it might
not be necessary, but do it anyway, for this test.
:=Pin 6 Clk - PIC B7
:=Pin 7 WP - Gnd
:=Pin 8 Vcc
:=The PIC will read in random data if I do not have the eeprom inserted in its circuit.  With the eeprom the PIC keeps on reseting.  I do a restart_wdt(); before the read_ext_eeprom(address).
What period are you using for the WDT ?
I suggest that you initially set it to the maximum,
while debugging this problem.  Put this line
near the start of your program:
setup_wdt(WDT_2304MS);
Also, the 2401.C file has a "delay_ms(11)" statement.
So I suggest that you add the "restart_wdt" parameter
to your "#use delay()" statement
#use delay(clock=4000000, restart_wdt)
What crystal frequency are you using ?
	Original Post ID: 144515304 |
			Harrison P Guest
				 Posted: Mon Jun 16, 2003 2:49 pm     |
				:=:=I am having some major troubles with the 24LC01B serial eeprom.  I enabled WDT because the program that I am using requires wdt to work correctly.  I am using the device driver 2401.c include file.  I have changed the
:=:=#define EEPROM_SDA  PIN_B6
:=:=#define EEPROM_SCL  PIN_B7
:=:=to match my program settings.
:=So that means you are using pins B6 and B7 ?
:=Are you using an ICD debugger ?
:=Those pins are used by the ICD.
I am not using a debugger but I am using a bootloader but those pins are not used.
:=Also, have you tested your program without the WDT ?
:=Does it work ?
:=:=Here is my setup:
:=:=PCM 3.102
:=:=24LC01B:
:=:=Pin 1 Floating
:=:=Pin 2 Floating
:=:=Pin 3 Floating
:=:=Pin 4 Gnd
:=:=Pin 5 Data - PIC B6 - 10k pullup
:=I always put a pull-up on the clock pin.
:=According to the Microchip appnote, it might
:=not be necessary, but do it anyway, for this test.
I will try a pullup on the clk pin also.
:=:=Pin 6 Clk - PIC B7
:=:=Pin 7 WP - Gnd
:=:=Pin 8 Vcc
:=:=The PIC will read in random data if I do not have the eeprom inserted in its circuit.  With the eeprom the PIC keeps on reseting.  I do a restart_wdt(); before the read_ext_eeprom(address).
:=What period are you using for the WDT ?
:=I suggest that you initially set it to the maximum,
:=while debugging this problem.  Put this line
:=near the start of your program:
:=setup_wdt(WDT_2304MS);
I have tried that and the PIC waits about 2.5 seconds before the wdt kicks in and restarts the PIC which sounds right.
:=Also, the 2401.C file has a "delay_ms(11)" statement.
:=So I suggest that you add the "restart_wdt" parameter
:=to your "#use delay()" statement
:=#use delay(clock=4000000, restart_wdt)
:=What crystal frequency are you using ?
I am using a 20 mhz crystal.
	Original Post ID: 144515305 |
				 Posted: Mon Jun 16, 2003 3:22 pm     |
				If you try those things and it doesn't work, then post
a short, but complete program that demonstrates the problem.
Be sure to post all compiler pre-processor directives.
Also, post what bootloader you are using, and the
power supply voltage that you're using for the PIC
the and eeprom.
	Original Post ID: 144515307 |
