Why is max set to 0 and min to 255 in the code?
kel
PostPosted: Tue Dec 27, 2005 10:11 pm     Reply with quote
from the following code, can some exolain to me why min is set 255 and max set 0 initially...i.e. min = 255; //and displays the min and max = 0; //values for that 100ms period
Thanks budds..
Happy chrismass
#include<16f877a.h>
#fuses HS,NOLVP,NOWDT,PUT
#use rs232(baud=9600,xmit=PIN_C6,rcv=PIN_C7)
void main() {
   int i, value, min, max;
   printf("Sampling:");
   setup_adc_ports( RA0_ANALOG );
   setup_adc( ADC_CLOCK_INTERNAL );
   set_adc_channel( 0 );
   do {                       //Takes 30 samples from pin A0
      for(i = 0; i <= 30; ++i) {
         value = read_adc();
         if(value < min)
            min = value;
         if(value > max)
            max = value;
      printf("\n\rMin:%x MAX: %x", min, max);
   } while (TRUE);
[/code]
jecottrell
PostPosted: Tue Dec 27, 2005 10:42 pm     Reply with quote
Those are "seed" values for the first comparison of the values of interest. If "min" was initially defined as 100 any value between 100 and 255 would not be registered as a new min.
Good luck,
John
kel
why not the otherway around?
PostPosted: Tue Dec 27, 2005 11:08 pm     Reply with quote
Why not the min=0; and max=255 instead?
jecottrell
PostPosted: Tue Dec 27, 2005 11:40 pm     Reply with quote
If you initialized "min" with zero and "max" with 255 everytime through the MAIN DO LOOP you'd get:
Min:0 MAX:ff
(I think that is the correct formatting for %x)
Look at the comparisons and give yourself a couple of "for instance" ADC readings and see how the code works. Remember you'll never get a value smaller than 0 or greater than 255.... The new min value would never get put into the min variable and the new max value would never get put into the max variable....
newguy
PostPosted: Tue Dec 27, 2005 11:53 pm     Reply with quote
I have to agree with jecottrell here. If you want your code to work as you intended, you need to do an initial read of the A/D, right after you initialize it, and just before your do.....while loop.
i.e.:
min = read_adc();
max = min;
This sets your max and min to be the same, but more importantly within the range you'll see.
PostPosted: Wed Dec 28, 2005 2:33 am     Reply with quote
i.e.:
min = read_adc();
max = min;
The code as given is correct. Your suggested change is just another method of getting the same result at the cost of an extra call to read_adc().
jecottrell
PostPosted: Wed Dec 28, 2005 7:20 am     Reply with quote
Upon re-reading your original post I see I missed a subtle but important point that may be confusing you.
It appears your ADC may be reading 0 constantly and you're assuming that the code is behind getting a min and max = 0? (HINT: The code is not the problem.)
         value = read_adc();
         if(value < min)
            min = value;
         if(value > max)
            max = value;
   } while (TRUE);
Also, the comment about taking thirty samples and reporting for a 100ms period is incorrect. The 100mS delay is within the FOR loop. (HINT: 30 x 100mS = ?)
Newguy, my suggestion was not to change the code, it was to sit down with pencil and paper and what if some values through the code to see how it reacted. I'm afraid I'm a victim of my own unclear explanation... I also agree with ckielstra that the initial ADC is not required.
Maybe our biggest problem here is translating between Australian, American, Canadian, and Dutch English?
I will reiterate my original suggestion. Give yourself some "made-up" ADC readings between 0 and 255 and step through the code and see how it reacts. Make a column for "min" and "max" and note their values each time through and I think you'll see what I'm talking about.
Good luck,
John
newguy
PostPosted: Wed Dec 28, 2005 10:47 am     Reply with quote
Doh!
I hate it when I miss things! I just now realized that he was setting 'min' to 255 and 'max' to 0. When I first read that, my mind switched them around. You're right - setting the variables like this is proper, no extra read is required.
Very Happy
You're probably right! I've run into this type of thing before......just so you know, the north american definition of 'fanny' is vastly different from the British definition! Wink
