How to program Keypad
crushneck
PostPosted: Thu Dec 22, 2005 1:19 am     Reply with quote
How to program a 4x3 keypad and get and output from LCD...?
Im using a PIC16F877 and using PORT b for keypad and port D for LCD...
PostPosted: Thu Dec 22, 2005 1:32 am     Reply with quote
Look at these CCS example and driver files:
EX_LCDKB.C
KBD.C
LCD.C
These files are in:
c:\Program Files\Picc\Examples
and
c:\Program Files\Picc\Drivers
crushneck
Which pins??
PostPosted: Thu Dec 22, 2005 3:07 am     Reply with quote
i still have some question for the conection to port B..i didnt know which pin to which pin...maybe u can take a look at my keypad schematic diagram..its at the page 4 of 4...Components layout...12 keys - Connector
Maybe u can help me more...thanks
http://www.farnell.com/datasheets/26652.pdf
Mark
PostPosted: Thu Dec 22, 2005 11:07 am     Reply with quote
#define COL0 (1 << 2)
This would be on B2 or D2
#define COL1 (1 << 3)
This would be on B3 or D3
#define COL2 (1 << 6)
This would be on B6 or D6
You should be able to figure out the rest.
Make sure you pay attention to the #ifdef's to know what code is actually being used. The code will behave differently depending on what is #define'd
PostPosted: Thu Dec 22, 2005 11:40 am     Reply with quote
Here is a table that shows the connections you must make
between your keypad connector pins and Port B on the PIC:
Keypad   Port
pin      pin
X3 ------ B7
X2 ------ B6
X1 ------ B5
Y4 ------ B4
Y3 ------ B3
Y2 ------ B2
Y1 ------ B1
Other required changes:
1. Edit the KBD.C file and un-comment the following line:
// #define use_portb_kbd TRUE
so it looks like this:
2. Edit the EX_LCDKB.C file, and add a line to enable Port B pullups.
Add the line shown in bold below:
void main() {
char k;
port_b_pullups(TRUE);
kbd_init();
lcd_putc("\fReady...\n");
while (TRUE) {
k=kbd_getc();
if(k!=0)
if(k=='*')
lcd_putc('\f');
lcd_putc(k);
crushneck
PostPosted: Fri Dec 23, 2005 2:11 am     Reply with quote
Yeah it works!!thanks Very Happy ...but 1 more thing...
The numbers/letter apeared in the LCD...but it always overwrite each other....i want it to apear beside each other whenever a key is pressed
PostPosted: Fri Dec 23, 2005 12:08 pm     Reply with quote
Go to this website
http://www.geocities.com/dinceraydin/lcd/commands.htm
Scroll down to the section on:
Entry mode set command 06h
He has an animated display that shows how the LCD should look when
you initialize it with the 0x06 command.
In the CCS driver file, LCD.C, there is an array with the initialization
commands. Notice that the last byte is 6.
BYTE const LCD_INIT_STRING[4] = {0x20 | (lcd_type << 2), 0xc, 1, 6};
So if you used the CCS driver, your LCD should be initialized correctly.
Did you change the values in that array ?
Another reason for your problem could be that you are clearing the
LCD screen after each character. The LCD is cleared by sending
the '\f' character (same as 0x0C) to the lcd_putc() function. Example:
lcd_putc('\f');
Are you clearing the screen after sending each character ?
If so, don't do that.
crushneck
PostPosted: Mon Dec 26, 2005 7:36 pm     Reply with quote
yes im using the character /f...but other than clearing the
LCD screen after each character,what other kind of character must i use??
Heres my main source code which contain the characters:
#include <16F877.h>
#use rs232(baud=9600,parity=N,xmit=PIN_C6,rcv=PIN_C7,ERRORS)  //pin25=c6, pin26=c7
#include <lCD420.c>
#include <kbd.c>
void main() {
char k;
kbd_init();
while (TRUE) {
k=kbd_getc();
if(k!=0)
if(k=='*')
lcd_putc("\f*\n");
if(k=='#')
lcd_putc("\f#\n");
if(k=='0')
lcd_putc("\f0123456789012345678901234567890\n");
if(k=='1')
lcd_putc("\f1\n");
if(k=='2')
lcd_putc("\f2\n");
if(k=='3')
lcd_putc("\f3\n");
if(k=='4')
lcd_putc("\f4\n");
if(k=='5')
lcd_putc("\f5\n");
if(k=='6')
lcd_putc("\f6\n");
if(k=='7')
lcd_putc("\f7\n");
if(k=='8')
lcd_putc("\f8\n");
if(k=='9')
lcd_putc("\f9\n");
And heres my LCD420 code
struct lcd_pin_map {
           BOOLEAN rs;          // Pin D0
           BOOLEAN enable;      // Pin D1
           BOOLEAN rw;          // Pin D2
           BOOLEAN unused;
           int     data : 4;    // Pins D4-D7
        } lcd;
#byte lcd = 8                        // This puts the entire structure
                                     // on to port D (at address 8)
#define lcd_type 2           // 0=5x7, 1=5x10, 2=2 lines
                             // These bytes need to be sent to the LCD
                             // to start it up.
                             // The following are used for setting
                             // the I/O port direction register.
struct lcd_pin_map const LCD_WRITE = {0,0,0,0,0}; // For write mode all pins are out
struct lcd_pin_map const LCD_READ = {0,0,0,0,15}; // For read mode data pins are in
BYTE lcdline;
BYTE lcd_read_byte() {
      BYTE low,high;
      set_tris_d(LCD_READ);
      lcd.rw = 1;
      delay_cycles(1);
      lcd.enable = 1;
      delay_cycles(1);
      high = lcd.data;
      lcd.enable = 0;
      delay_cycles(1);
      lcd.enable = 1;
      delay_us(1);
      low = lcd.data;
      lcd.enable = 0;
      set_tris_d(LCD_WRITE);
      return( (high<<4) | low);
void lcd_send_nibble( BYTE n ) {
      lcd.data = n;
      delay_cycles(1);
      lcd.enable = 1;
      delay_us(2);
      lcd.enable = 0;
void lcd_send_byte( BYTE address, BYTE n ) {
      lcd.rs = 0;
      while ( bit_test(lcd_read_byte(),7) ) ;
      lcd.rs = address;
      delay_cycles(1);
      lcd.rw = 0;
      delay_cycles(1);
      lcd.enable = 0;
      lcd_send_nibble(n >> 4);
      lcd_send_nibble(n & 0xf);
void lcd_init() {
    BYTE i;
    lcd.rs = 0;
    lcd.rw = 0;
    lcd.enable = 0;
    delay_ms(15);
    for(i=1;i<=3;++i) {
       lcd_send_nibble(3);
       delay_ms(5);
    lcd_send_nibble(2);
    for(i=0;i<=3;++i)
       lcd_send_byte(0, LCD_INIT_STRING[i]);
void lcd_gotoxy( BYTE x, BYTE y) {
   BYTE address;
   switch(y) {
     case 1 : address=0x80;break;
     case 2 : address=0xc0;break;
     case 3 : address=0x94;break;
     case 4 : address=0xd4;break;
   address+=x-1;
   lcd_send_byte(0,address);
void lcd_putc( char c) {
   switch (c) {
     case '\f'   : lcd_send_byte(0,1);
                   lcdline=1;
                   delay_ms(2);
     case '\n'   : lcd_gotoxy(1,++lcdline);        break;
     case '\b'   : lcd_send_byte(0,0x10);  break;
     default     : lcd_send_byte(1,c);     break;
char lcd_getc( BYTE x, BYTE y) {
   char value;
    lcd_gotoxy(x,y);
    lcd.rs=1;
    value = lcd_read_byte();
    lcd.rs=0;
    return(value);
I hope u can help....thanks
PostPosted: Mon Dec 26, 2005 7:50 pm     Reply with quote
while (TRUE) {
k=kbd_getc();
if(k!=0)
if(k=='*')
lcd_putc("\f*\n");
if(k=='#')
lcd_putc("\f#\n");
if(k=='0')
if(k=='1')
lcd_putc("\f1\n");
What's wrong with using the code in the CCS example ?
It does not do the '\f' before each character.
You should use the example code:
void main() {
   char k;
   kbd_init();
   while (TRUE) {
      k=kbd_getc();
      if(k!=0)
        if(k=='*')
          lcd_putc('\f');
          lcd_putc(k);
crushneck
PostPosted: Mon Dec 26, 2005 9:07 pm     Reply with quote
ok ive changed the code...it works well...thanks...
i have a question...im using an analog input at port RA0...so can i get the input of the analog in my LCD?....like example how many voltage,temperature,any value from the input of the analog...
PostPosted: Mon Dec 26, 2005 10:41 pm     Reply with quote
This program will display the A/D value in the upper left corner of the LCD.
#include <16F877.H>
#device adc=10
#include <lcd.c>
int16 result;
setup_adc_ports(AN0);
setup_adc(ADC_CLOCK_DIV_8);
set_adc_channel(0);
   result = read_adc();
   lcd_gotoxy(1,1);
   printf(lcd_putc, "%04LX", result);
crushneck
PostPosted: Wed Dec 28, 2005 7:51 pm     Reply with quote
thanks for the codes...it works fine now..thanks alot... Laughing
crushneck
Upgrade to PIC18F452
PostPosted: Wed Feb 01, 2006 10:07 am     Reply with quote
I decided to upgrade my PIC to PIC18F452 but then my circuit did not work...what need to be done to my code for it to work??
#include <18F452.H>
#device adc=10
#include <lcd.c>
int16 result;
set_adc_channel(0);
   lcd_gotoxy(1,1);
