ADC using ... PIC18f2331
sonicdeejay
PostPosted: Tue Dec 20, 2005 1:18 am     Reply with quote
May I know how can I write a analog to digital conveter using PIC18F2331??
PortA 0 will be input for analog in....
and PortB 0 will be digital output for for the digitalised signal from PortA 0.
Thanks in advance...
Smile
PostPosted: Tue Dec 20, 2005 12:29 pm     Reply with quote
May I knw how can I write a analog to digital conveter using PIC18F2331??
PortA 0 will be input for anlog in....
PortB 0 will be digital output for for the digitalised signal from port A 0.
Study these functions in the CCS manual and in the example files:
setup_adc_ports()
setup_adc()
read_adc()
set_adc_channel()
output_b()
Download the CCS manual here:
http://www.ccsinfo.com/ccscmanual.zip
The example files are in this folder:
c:\Program Files\PICC\Examples
sonicdeejay
PostPosted: Sat Jan 14, 2006 1:30 am     Reply with quote
Guys,,,I can make it works...thanks for help...
#include<16f877a.h>
#fuses HS,NOLVP,NOWDT,PUT
#use rs232(baud=9600,xmit=PIN_C6,rcv=PIN_C7)
void main() {
int i, value, min, max;
printf("Sampling:");
setup_adc_ports( RA0_ANALOG );
setup_adc( ADC_CLOCK_INTERNAL );
set_adc_channel( 0 );
do { //Takes 30 samples from pin A0
min = 255; //and displays the min and max
max = 0; //values for that 100ms period
for(i = 0; i <= 30; ++i) {
value = read_adc();
if(value < min)
min = value;
if(value > max)
max = value;
printf("\n\rMin:%x MAX: %x", min, max);
} while (TRUE);
The above ADC sample show that it reads "Input" from Port A0, calculates max, min etc and display via RS232....
Smile
