rs485
rutnn33
rs485
PostPosted: Mon Dec 19, 2005 10:03 am     Reply with quote
Hello
I am trying implement a rs485 network using CCS rs485.c file. I use adm485 tranceiver. I believe that I have the hardware setup correct. My code compiles OK but both the master and slave could not receive anything. The master transmits ok. (compiler version 3.222, picdem2 plus boards). Thank you
//master
#include<18f452.h>
#fuses HS, NOWDT, NOLVP, NOBROWNOUT, NOPROTECT, PUT
#use delay(clock = 4000000)
#define RS485_ID  0x10                 // The device's RS485 master address
#define RS485_USE_EXT_INT TRUE        // Select asynchronous serial interrupt
#include<RS485.c>
int buffer[40];
int next_in  = 0;
int next_out = 0;
#INT_RDA
void serial_isr()
   int t;
   buffer[next_in] = fgetc(RS485);
   t = next_in;
   next_in = (next_in+1) % sizeof(buffer);
   if(next_in == next_out)
      next_in=t;        // Buffer full !!
   int j;
   int data_received[32];
   enable_interrupts(INT_RDA);
   rs485_init();
      rs485_wait_for_bus(FALSE);
                   //send address=0x11, length = 1, msg=3
                                //the led does blink here
      if(rs485_send_message(0x11, 1, 3))
         output_low(PIN_B1);
         output_high(PIN_B1);
         output_low(PIN_B1);
      delay_ms(5);
      if(rs485_get_message(data_received, FALSE))
         for(j=0;  j<3; ++j)
                  data_received[j] = buffer[j];
               if(data_received[2]==6)         //if slave receives the number 3 successfully
         {                    //slave will send back number 6
            output_low(PIN_B2);
            output_high(PIN_B2);
            output_low(PIN_B2);
//slave
#include<18f452.h>
#define RS485_ID  0x11                 // The device's RS485 slave address or ID
#include<RS485.c>
int buffer[40];
int next_in  = 0;
int next_out = 0;
#INT_RDA
void serial_isr()
   int t;
   t = next_in;
   int i=1;
   int j;
   rs485_init();
      if(rs485_get_message(data_received, TRUE))
         for(j=0;  j<3; ++j)
         if(data_received[0] == 0x11)
            output_low(PIN_B2);
            output_low(PIN_B2);
            //after receive successfully, respond to master by sending number 6
            if(rs485_send_message(0x10, 1, 6))
               output_low(PIN_B1);
               output_low(PIN_B1);
John Morley
PostPosted: Mon Dec 19, 2005 10:46 am     Reply with quote
I'd write a very simple test program to test your hardware that uses getc and putc to echo any characters received. Put these calls inside a while loop in Main(), and don't use the serial interrupt until this is working. Also, do you have an RS-232 to RS-485 converter? While I was developing an RS-485 application, I found it very useful to send and receive data using a PC (using Hyperterminal) with the PIC.
John
John Morley
Humberto
PostPosted: Mon Dec 19, 2005 10:48 am     Reply with quote
#include<RS485.c>
This included general RS485.C reference file has the Pre-processor directives:
#use rs232(baud=9600, xmit=RS485_TX_PIN, rcv=RS485_RX_PIN, enable=RS485_ENABLE_PIN, bits=9, long_data, errors, stream=RS485)
It is your job to re-check that the Pins definitions contained on there are in coincidence with the hardware UART of the PIC used in your application.
Humberto
rutnn33
PostPosted: Mon Dec 19, 2005 10:51 am     Reply with quote
Thank you.
I do not have a rs232-485 converter. "I will try to use getc". I have tried simple getchar and putchar and it works.
Thank you John.
I have checked the pins and they are correct Humberto. Thank you
