Problem with Int_RDA
John Morley
PostPosted: Fri Dec 16, 2005 6:34 pm     Reply with quote
Hi all,
I'm experiencing a strange problem getting the serial interrupt to work on a 16F628 using compiler version 3.162. I know my hardware is OK because I can do this:
Main()
        char c;
      c=fgetc(Console);
      fputc(c,Console);
   } // while
All the characters I type on Hyperterminal get echoed right back correctly. However, when I try to use an interrupt to do basically the same thing it doesn't work Sad
Here is a small test program:
//-----< Include Files, setup fuses >-----
#include <16f628.h>
#fuses HS, NOWDT, NOPROTECT, NOLVP
//-----< Compiler use statements >-----
// Tell compiler clock speed is 20.00 MHZ Crystal
//-----< General Program Defines >-----
#define Console_Out PIN_A4      // Software RS232 Output to Console Terminal (requires MAX232)
#define Console_In PIN_B1      // Hardware RS232 Input from Console Terminal (requires MAX232)
//-----< Serial Port Definitions >-----
#use rs232(baud=9600, xmit=Console_Out, rcv=Console_In, ERRORS, STREAM=Console)
//-----< Get a RS232 command packet >-----
// Note: This routine is interrupt driven. RS232 input takes priority
// over every other operation in the system.
#int_rda   // Interrupt driven RS232 routine
void rs232_isr(void)
   char temp;   // local data storage
   temp = fgetc(Console);   // get rx data
   fputc(temp, Console);
Main()
   enable_interrupts(INT_RDA);
   fprintf(Console,"\n\rHere at the start\n\r");
   } // while
} // end Main
When I run this code I never see any characters echoed back. I can see the data arrive just fine at Pin B1 on a scope, but the interrupt doesn't fire!
Any thoughts?
Thanks!
John
John Morley
PostPosted: Fri Dec 16, 2005 6:54 pm     Reply with quote
You can't split the hardware UART pins. It's either all hardware or
all software. If you make one pin of the hardware UART become a
software UART, then both pins will be a soft UART. This is a limitation
of the PIC hardware. INT_RDA only works with the hardware UART.
To get a hardware UART for the 16F628, you need to use these pins:
use rs232(baud=9600, xmit=PIN_B2, rcv=PIN_B1, ERRORS, STREAM=Console)
John Morley
PostPosted: Fri Dec 16, 2005 9:19 pm     Reply with quote
PCM,
Thanks for catching that. I'm not sure if it solves my problem, however, as I was never using a serial out to begin with, but added it when I has trouble with the serial interrupt. I'll make the serial output a separate stream for the purposes of my testing and report back.
Thanks Again!
John
John Morley
John Morley
PostPosted: Mon Dec 19, 2005 8:50 am     Reply with quote
Hi All,
I made a change to my test program this morning to separate the serial input and output onto two distinct streams, but I still can't get the serial interrupt to work at all. Again, compiler is version 3.162.
#include <16f628.h>
#define Test_Output PIN_A1      //Pin #18
#use rs232(baud=9600, rcv=Console_In, ERRORS, STREAM=Console1)
#use rs232(baud=9600, xmit=Console_Out, STREAM=Console2)
   temp = fgetc(Console1);   // get rx data
   fputc(temp, Console2);
Main()
   fprintf(Console2,"\n\rHere at the start\n\r");
   } // while
} // end Main
Again, I know my hardware is OK because I can put the fgetc and the fputc in Main, and all characters are echoed just fine. But for some reason it won't work using the interrupt Sad
Thanks!
John
John Morley
PostPosted: Mon Dec 19, 2005 2:08 pm     Reply with quote
Let me be more explicit.
You cannot define half of a hardware serial port with a #use rs232()
statement. If you try to do so, the compiler generates a software UART.
i.e., the following statement in your program will make a soft UART:
or more plainly:
#use rs232(baud=9600, rcv=PIN_B1)
To get a hardware UART, you must put both hardware UART pins
in the #use rs232() statement. Example for 16F628:
#use rs232(baud=9600, xmit=PIN_B2, rcv=PIN_B1, ERRORS)
Also, the ERRORS directive only works with the hardware UART.
If you include it with a soft UART, the compiler will ignore it.
John Morley
PostPosted: Mon Dec 19, 2005 8:59 pm     Reply with quote
PCM,
Ugh, I've got it now Smile ! Thanks for taking another swing at this one, I really appreciate it! And, yes, it's working!!
Thanks!
John
John Morley
