ORG errors with bootloader
darryl
PostPosted: Fri Dec 16, 2005 2:27 pm     Reply with quote
I'm having some odd problems since updating my compiler. I am using a bootload based on the example code which came with the compiler. My target is a PIC18F6720.
The following code use to work fine in my main application. Now it causes an "Invalid ORG Range" error. I've tried changing a number of things but to no avail.
Has anybody come across this before?
#define LOADER_END   0xfFF
#define LOADER_SIZE   0xdff
#ifndef _bootloader
#define VERSION_HIGH  ((FIRMWARE_VERSION)>>8)
#define VERSION_LOW ((FIRMWARE_VERSION)&0xff)
#if defined(__PCM__)
   #build(reset=LOADER_END+1, interrupt=LOADER_END+5)
#elif defined(__PCH__)
   #build(reset=LOADER_END+2, interrupt=LOADER_END+8)
#org 0, LOADER_END {}
PostPosted: Fri Dec 16, 2005 2:40 pm     Reply with quote
1. Were you using a different PIC for the code that worked ?
If so, what PIC were you using ?
2. Did you change compiler versions ? What was your old version
and what is your current version ?
darryl
PostPosted: Mon Dec 19, 2005 3:06 pm     Reply with quote
1) we've always been using the same PIC 18F6720
2) It use to work fine on previous compiler versions 3.191, 3.202, 3.204, but does not now work on our current version 3.241.
PostPosted: Mon Dec 19, 2005 3:57 pm     Reply with quote
If I take your code and drop it into a test program, it compiles with
no errors with PCH vs. 3.241.
#include <18F6720.H>
#fuses XT,NOWDT,PUT,BROWNOUT,NOLVP
#ifndef _bootloader
Howard
ORG_errors with bootloader
PostPosted: Mon Dec 19, 2005 11:05 pm     Reply with quote
If you try the following code it causes the problem. It appears to be related to using interupts. Remove the interrupt and it compiles properly using PCH ver 3.241
#ifndef _bootloader
int i;
#INT_RTCC
   void rtc_code() {
      i++;
PostPosted: Tue Dec 20, 2005 1:17 am     Reply with quote
To get it to compile with PCH vs. 3.241, I had to increase the value
shown in bold below to 9. I'm not sure how this will affect your
program. You'll have to look at the .LST file.
#build(reset=LOADER_END+2, interrupt=LOADER_END+9)
agrj
PostPosted: Tue Dec 27, 2005 1:51 pm     Reply with quote
It worked for me.
thanks!!
