RTOS and PIC18F2525
bernardinim
RTOS and PIC18F2525
PostPosted: Tue Dec 13, 2005 7:47 am     Reply with quote
Why the example code of ccs about rtos (for pic18f452) not work on pic18f2525. What's are the differences?
bernardinim
PostPosted: Wed Dec 14, 2005 2:34 am     Reply with quote
my rtos code not work.....
what is wrong in my code??
(I use a 32Mhz external clock)
#include <18F2525.h>
#device adc=8
#FUSES EC //External clock
#FUSES BORV20 //Brownout reset at 2.0V
#FUSES PUT //Power Up Timer
#FUSES NOLVP //Low Voltage Programming on B3(PIC16) or B5(PIC18)
#FUSES NOFCMEN //Fail-safe clock monitor enabled
#FUSES NOPBADEN //PORTB pins are configured as digital I/O on RESET
#FUSES NOLPT1OSC //Timer1 configured for low-power operation
#use delay(clock=32000000)
#use rtos(timer=0,minor_cycle=100ms)
#task(rate=1000ms,max=100ms)
void The_first_rtos_task()
output_high(PIN_C0);
delay_ms(50);
output_low(PIN_C0);
#task(rate=500ms,max=100ms)
void The_second_rtos_task()
delay_ms(50);
output_low(PIN_C0);
int i;
setup_spi(FALSE);
setup_wdt(WDT_OFF);
setup_timer_0(RTCC_INTERNAL|0x40);
setup_timer_1(T1_INTERNAL);
setup_vref(FALSE);
setup_low_volt_detect(FALSE);
setup_oscillator(False);
setup_oscillator(OSC_NORMAL);
printf("start\n\r");
set_timer0(0);
i=get_timer0();
printf("%d",i);
set_timer0(0);
i=get_timer0();
printf("%d",i);
rtos_run();
Can someone help me???
PostPosted: Wed Dec 14, 2005 7:46 pm     Reply with quote
does not work means ??
Your question is not complete.....
bernardinim
RTOS
PostPosted: Thu Dec 15, 2005 2:34 am     Reply with quote
The task not start... I tried different fuse configurations without success...
The strange thing is that the code work on PIC18F452 and not on PIC18F2525... I not know why... I think that rtos needs only a timer for schedule task...
cstan_02
PostPosted: Thu Dec 15, 2005 7:43 pm     Reply with quote
set_timer0(0);
i=get_timer0();
printf("%d",i);
set_timer0(0);
i=get_timer0();
printf("%d",i);
rtos_run();
Have you tried assigning a different timer for RTOS, say timer 1 ??
I'm afraid that you may be using the timer0 that is being assigned to the RTOS.
