Hi.. I am using 18F2550. And I want to use same SPI PINs for two
different ICs. For that I have used latch to handle one by one.
It seems one chip is working and other is not working.
Is it possible to communicate like that? Or I have to send "setup_spi()"
everytime for that perticular chip?
Thanks...
asmallri
Posted: Wed Dec 14, 2005 2:56 am
Can you give some more information.
If you mean you have one device (the PIC) talking to two other SPI devices then... If the PIC is the master , then the SPI bus is connected to all devices and you use a spearate CS line from the PIC to each of the devices. _________________ Regards, Andrew
