Problem with 12F683
prayami
Problem with 12F683
PostPosted: Mon Dec 12, 2005 7:08 pm     Reply with quote
Hi..I am using 12F683 to generate 10Khz pulse. I am using CCS PCM C Compiler, Version 3.206 . I tried a lot but could not generate output
pulses on PIN_A4 . Here is the code:
Can anybody figure out the problem please.....
#CASE
#include <12F683.h>
#fuses INTRC_IO,NOBROWNOUT,NOMCLR,NOWDT,PROTECT,PUT,NOCPD,NOIESO,NOFCMEN
int1 High=0;
void main() {
   setup_oscillator(OSC_4MHZ); // select 4MHz internal clock
   set_tris_a(0x2B); // A0-A5 Output
   setup_adc(ADC_OFF);
   setup_adc_ports(NO_ANALOGS);
   setup_comparator(NC_NC_NC_NC);   // Disable comparators
    setup_vref(FALSE);
     output_low(PIN_A4); // INT/HOLD signal
   delay_us(50);
   while(TRUE) {
      if(High==0)
           output_high(PIN_A4);
         High=1;
         High=0;
           output_low(PIN_A4);
      }//if(High==0)
      delay_us(29);
   }//while(TRUE)
}//main
and here is the .lst file.....
CCS PCM C Compiler, Version 3.206, 24476               13-Dec-05 14:02
               Filename: Knock_IntHold.LST
               ROM used: 88 words (4%)
                         Largest free fragment is 1960
               RAM used: 7 (5%) at main() level
                         7 (5%) worst case
               Stack:    0 locations
0000:  MOVLW  00
0001:  MOVWF  0A
0002:  GOTO   004
0003:  NOP
0004:  MOVLW  07
0005:  MOVWF  0A
0006:  CALL   7FF
0007:  BSF    03.5
0008:  MOVWF  10
0009:  MOVLW  00
000A:  MOVWF  0A
000B:  GOTO   00C
.................... #CASE
.................... #include <12F683.h>
....................  //////// Standard Header file for the PIC12F683 device ////////////////
.................... #device PIC12F683
.................... #list
.................... #fuses INTRC_IO,NOBROWNOUT,NOMCLR,NOWDT,PROTECT,PUT,NOCPD,NOIESO,NOFCMEN
.................... #use delay(clock=4000000)
.................... int1 High=0;
001B:  BCF    03.5
001C:  BCF    25.0
.................... void main() {
000C:  CLRF   04
000D:  MOVLW  1F
000E:  ANDWF  03,F
000F:  BCF    1F.6
0010:  BSF    03.5
0011:  BSF    1F.0
0012:  BSF    1F.1
0013:  BSF    1F.2
0014:  BSF    1F.3
0015:  MOVLW  07
0016:  BCF    03.5
0017:  MOVWF  1F
0018:  MOVLW  60
0019:  BSF    03.5
001A:  MOVWF  0F
....................    setup_oscillator(OSC_4MHZ); // select 4MHz internal clock
001D:  MOVLW  60
001E:  BSF    03.5
001F:  MOVWF  0F
....................    set_tris_a(0x2B); // A0-A5 Output
0020:  MOVLW  2B
0021:  TRIS   5
....................    setup_adc(ADC_OFF);
0022:  BCF    03.5
0023:  BCF    1F.0
....................    setup_adc_ports(NO_ANALOGS);
0024:  BCF    1F.6
0025:  BSF    03.5
0026:  BCF    1F.0
0027:  BCF    1F.1
0028:  BCF    1F.2
0029:  BCF    1F.3
....................    setup_comparator(NC_NC_NC_NC);   // Disable comparators
002A:  MOVLW  07
002B:  BCF    03.5
002C:  MOVWF  19
002D:  BSF    03.5
002E:  MOVF   05,W
002F:  MOVLW  03
0030:  BCF    03.5
0031:  MOVWF  20
0032:  DECFSZ 20,F
0033:  GOTO   032
0034:  MOVF   19,W
0035:  BCF    0C.3
....................     setup_vref(FALSE);
0036:  BSF    03.5
0037:  CLRF   19
....................      output_low(PIN_A4); // INT/HOLD signal
0038:  BCF    05.4
0039:  BCF    03.5
003A:  BCF    05.4
....................    delay_us(50);
003B:  MOVLW  10
003C:  MOVWF  20
003D:  DECFSZ 20,F
003E:  GOTO   03D
003F:  NOP
....................    while(TRUE) {
....................       if(High==0)
0040:  MOVLW  00
0041:  BTFSC  25.0
0042:  MOVLW  01
0043:  XORLW  00
0044:  BTFSS  03.2
0045:  GOTO   04C
....................            output_high(PIN_A4);
0046:  BSF    03.5
0047:  BCF    05.4
0048:  BCF    03.5
0049:  BSF    05.4
....................          High=1;
004A:  BSF    25.0
....................       else
004B:  GOTO   051
....................          High=0;
004C:  BCF    25.0
004D:  BSF    03.5
004E:  BCF    05.4
004F:  BCF    03.5
0050:  BCF    05.4
....................       }//if(High==0)
....................       delay_us(29);
0051:  MOVLW  09
0052:  MOVWF  20
0053:  DECFSZ 20,F
0054:  GOTO   053
0055:  NOP
....................    }//while(TRUE)
0056:  GOTO   040
.................... }//main
0057:  SLEEP
Configuration Fuses:
   Word  1: 3084   NOWDT NOCPD PROTECT NOMCLR PUT INTRC_IO NOBROWNOUT NOIESO NOFCMEN
Thanks...
PostPosted: Mon Dec 12, 2005 7:55 pm     Reply with quote
I tried a lot but could not generate output pulses on PIN_A4 .
Your version of the compiler has a bug for the 12F683. Notice the
line in bold, below. It's calling 0x7FF, as if there is a RETLW instruction
there, with an OSCCAL value. But for the 12F683, this feature doesn't
exist. So doing this will cause the program to crash.
0000: MOVLW 00
0001: MOVWF 0A
0002: GOTO 004
0003: NOP
0004: MOVLW 07
0005: MOVWF 0A
0006: CALL 7FF
0007: BSF 03.5
0008: MOVWF 10
0009: MOVLW 00
000A: MOVWF 0A
000B: GOTO 00C
To fix the problem, use the #rom directive to put a RETLW 00
instruction at address 0x7FF. This will load 0x00 into the OSCTUNE
register (which is the default state), and your program will now run OK.
Add the line shown in bold, below:
#CASE
#include <12F683.h>
#rom 0x7FF = {0x3400}
prayami
PostPosted: Mon Dec 12, 2005 8:02 pm     Reply with quote
Thanks PCM programmer. It is working now with adding a one line you
suggested.
You are greate....
