Ive setup file association with the *.c extension. However it loads up PCW C IDE but not the *.c file i double clicked on. I checked the file association again and its automatically added %1 is the command line and setup the DDE with application anme "Pcw" and topic "System".
Am I missing something?
Posted: Mon Dec 12, 2005 12:52 pm
I don't have PCW so I can't check the file association. But I know that
some applications require quotes around the %1. For example:
"C:\Program Files\Accessories\WORDPAD.EXE" "%1"
