Deepak Guest
| Read_ADC reads wrong values ? |
Posted: Fri Dec 09, 2005 12:10 pm |
Hello, I am using a TMP36 temperature sensor interfaced to my PIC18F252. I have defined #device ADC = 8 bits resolution. When I checked the voltage output at the temperature sensor or at the pin of the microcontroller using a multimeter I see almost constant value ( say 0.65 corresponding to 15 deg C) But when I print the Read_ADC value I see it fluctuates a lot. (for ex 5 deg C to 27 deg C) and yeah basically it gives wrong digitized readings most of the time. Here is the code I use to read the temperature reading. Is this got to do with delay I set ? I am calling the function to read temperature continuosly every 1 second.
#include <18f252.h> //18f252 pic mcu
#device ADC=8;
// inside the function to calculate temperature
set_adc_channel(4);
delay_us(10);
V_temp1 = Read_ADC();
Vout_temp = (float) V_temp1;
printf(" Temperature (digitized value) = %f \r\n", Vout_temp);
I am using PIC C Compiler IDE version 3.215 PCH 3.217 |
Posted: Fri Dec 09, 2005 12:14 pm |
I forgot to add these two lines of code I use to set up the ADC ports
setup_adc_ports(ALL_ANALOG);
setup_adc(ADC_CLOCK_DIV_32);
kender
Posted: Fri Dec 09, 2005 12:35 pm |
| If you think that it's a settling delay - increase it from 10uS to 1mS and see if it helps. Also, the line conecting the temperature sensor to the PIC might be picking up noise (probably 60hZ, especially if it's an off-board sensor), which you don't see with the multimeter. So, you could try adding an RC filter or just a capacitor to ground. |
deepak Guest
Posted: Fri Dec 09, 2005 12:45 pm |
Thanks for your reply. I already did that and some other delay values as well but it seems to give me the same results. The sensor is on board and it gives a voltage output which I have directly interfaced to the PIC.
is Vref may be something of concern ? I have defined all ports as analog and so it should take my VDD as Vref ? I checked the VDD on the PIC and it was 5.1V. Or is the number of bits causing any problem ? any suggestions most welcome |
Humberto
Posted: Fri Dec 09, 2005 12:49 pm |
| Quote: |
Are you aware that the TMP36 has on open emitter output and that it need a pull down resistor to get a measurable voltage ?
| Quote: |
Yes.
Pls post a short and complete code that we can paste and test.
Humberto
deepak Guest
Posted: Fri Dec 09, 2005 1:01 pm |
here is the code
#include <18f252.h>
#device ADC=10;
#include <stdlib.h>
#include <stdio.h>
#use delay(clock = 20000000)
#fuses HS,NOPROTECT,NOCPD,NOCPB, NOWDT,NOLVP, NOBROWNOUT
#use rs232(baud = 9600, xmit = PIN_C6, rcv = PIN_C7)
#separate
void Setup_int()
enable_interrupts(global);
enable_interrupts(int_rda);
#separate
void temp_sensor()
// measure the sensor output voltage
set_adc_channel(4);
delay_ms(5);
Vout = (float) V_temp1 ;
Temp = ((Vout/204.8) - 0.5) * 100.0; // div by 1024/5 (=204.8) for 10 bit
printf("%f %f \r\n\n",Vout, Temp);
printf("Starting\r\n");
Setup_int();
do {
// Calculate Temperature
temp_sensor();
} while (TRUE);
deepak Guest
Posted: Fri Dec 09, 2005 1:06 pm |
updated code, i am using 8 bit ADC since I defined my variable that accepts the digitized values as byte
#include <18f252.h>
#device ADC=8;
#include <stdlib.h>
#include <stdio.h>
byte V_temp1;
float Vout, Temp;
#separate
void Setup_int()
#separate
void temp_sensor()
set_adc_channel(4);
delay_ms(5);
Setup_int();
do {
temp_sensor();
} while (TRUE);
deepak Guest
Posted: Fri Dec 09, 2005 1:30 pm |
One thing I found interesting is this,
I had defined ADC as 10 bit using # device ADC = 10. Then I defined a variable as long int.
When I did this,
long int temp1;
temp1 = Read_ADC();
it should return a digitized value in the 10 bit range right ? but I see it gives a value that is corresponding to the 8 bit range. |
Posted: Fri Dec 09, 2005 2:17 pm |
| Humberto wrote: |
no. so what resistance do I need to add ? a 4.7K ? But I do get almost right values and once in 10 readings get a wrong reading. It may be VDD for the slight variations I see. I measured the VDD and its 5.2V and voltage output at temperature sensor is 0.68V. Now this means 0.68/5.2 * 255 ( for 8 bit ADC) = 33.4 but I get 32.0 or 33.0 digitized reading. But I do not understand that some times I get ( once in 10 readings or so ) strange values. |
Posted: Fri Dec 09, 2005 2:20 pm |
I only saw this in the datasheet
| Quote: |
The output voltage of this circuit is not referenced to the circuit’s common ground. If this output voltage were applied directly to the input of an ADC, the ADC’s common ground should be adjusted accordingly. |
Humberto
Posted: Fri Dec 09, 2005 4:41 pm |
| Quote: |
Figure 25 (Page 10) of the datasheet shows you an example on how to create a virtual Gnd to compensate the ADC’s common ground.
Also shows the expected R values that the TMP36 needs in it's output.
| Quote: |
I assume:
1) you are not testing this in a protoboard or alike.
2) the decoupling .1uF (ceramic type) is connected across +Vs and Gnd.
3) the SHUTDOWN Pin (if present on your package) is connected to +Vs.
4) you had read that this device operate in very little supply current and that it's very sensitive to radio frequency interference or hostile electrical enviroments.
5) To minimize RFI, did you try with a 2.2 tantalum cap across the .1 as spec recommend ?
According to your description you have a hardware problem. Have not time to test your code today, but tomorrow I will do.
Humberto |
Posted: Wed Dec 14, 2005 12:54 pm |
| Humberto wrote: | | Quote: |
Humberto |
But this is for TMP35 and TMP37. Fig 26 represents the version for TMP36. But this says it is deg C to Fahrenheit conversion ?
I assume:
Humberto |
We have a proto board with 0.1uF cap is connected. shutdown pin is connected to Vs. But planning to respin the board. Hence if I want to use simple RC filter at the output, what values do i put in ? the output resistance on the TMP36 is 30 ohms.
Also Vref is 5.2 V. So I understood it digitizes from 0-5.2V rather than 0-5V ? there is a lower value reported because of this right ?
And the digitizing range is 0-Vdd whereas the output is from 0.5V to 1.75V. The data sheet says temperature variation is +/- 2 deg C. But I see a lot of fluctuation. Please provide any suggestions to improve the performance. |
Posted: Wed Dec 14, 2005 2:15 pm |
| Will it help if I just have a buffer at the output of the temperature sensor before sending it to the PIC ? |
