is my LCD dead?
young
is my LCD dead?
PostPosted: Fri Dec 09, 2005 9:34 am     Reply with quote
I used a 2x16 segment LCD and used lcd.c driver provided by ccs. I was able to write to the lcd long time ago using the following setup
PortB LCD
B7 D7
B6 D6
B5 D5
B4 D4
B0 Enable
B1 Rs
B2 Rw connected
however, is time I could not see anything on my lcd, it is blank, nothing happened to it, just like a lcd without connecting with anything? what might happened?
the following is a thread that I worked on lcd a long time ago!
[url]
http://www.ccsinfo.com/forum/viewtopic.php?t=19769&highlight=lcd[/url]
PostPosted: Fri Dec 09, 2005 10:51 am     Reply with quote
What have you got connected to the LCD bias voltage pin?.
What has to be here, varies with different makes/types, with some working with a +ve voltage and some (generally older) types requiring a
-ve voltage. Unless this voltage is in the right range, you will see nothing on most LCD's.
wolverine_349
PostPosted: Fri Dec 09, 2005 11:27 am     Reply with quote
Dude ,you sure u varied your contrast and checked ur voltage levels?i am currently working on 16x1Lcd which wasn't working until i changed the contrast n i saw all that i missed . Surprised .is the LCD module having a hitachi HD74880 based controller or wot.
since u r using 4bit mode ,make sure data transfers are done twice.wud b good if u verify that first.
good luck
young
PostPosted: Fri Dec 09, 2005 11:53 am     Reply with quote
Thank you:
which pin is LCD bias voltage pin?
I have a contrast pin Vo pin setup, and no matter how I adjust my contrast, it still show nothing?
young
PostPosted: Fri Dec 09, 2005 12:24 pm     Reply with quote
Ve=Vo
young
PostPosted: Fri Dec 09, 2005 12:38 pm     Reply with quote
my lcd came with a development board which Vo(Ve) is setup as pluse, no negative voltage, even I tried the testing program came with the board, it would not show anything!
any other suggestions? please?
wolverine_349
PostPosted: Fri Dec 09, 2005 12:45 pm     Reply with quote
could u post some of ur code here.also c if u can put link to the datasheet or something like that ,to know the LCD controller,and the display's electrical configuartion
good luck
young
PostPosted: Fri Dec 09, 2005 1:24 pm     Reply with quote
#if defined(__PCM__)
#include <16f76.h>
#fuses HS, NOBROWNOUT,NOWDT,NOPROTECT,NOPUT
#use delay(clock =8000000)
#use RS232(baud=9600, parity=N, xmit=PIN_C6, rcv=PIN_C7)
#include <lcd-1.c>
main()
lcd_init();
delay_ms(200);
printf("Pulse width measure ready!\r\n");
 printf("Waiting signal\r\n");
 printf(lcd_putc, "Waiting for start!");
The board is from Mikro, easypic2, old version, newer one is easypic3. the lcd is CMC216NO2
young
PostPosted: Fri Dec 09, 2005 2:34 pm     Reply with quote
I could not find the same data as for the LCD, here is a websit from mikro at page 19, it show the graph
http://www.mikroe.com/pdf/easypic3_manual.pdf
PostPosted: Fri Dec 09, 2005 3:50 pm     Reply with quote
Stick a delay in before the LCD_INIT call. Some current LCD's, are very slow indeed waking up, and LCD_INIT can be too quick on these.
young
PostPosted: Mon Dec 12, 2005 4:15 pm     Reply with quote
Thank you everybody:
I bought another LCD from digikey, the new part works fine, I can see the character. thank you all!
