SETUP_COUNTERS() with RTCC_INTERNAL??
husq
PostPosted: Thu Dec 08, 2005 3:19 pm     Reply with quote
I have been looking around for a similar project so I wouldn't have to put another one in the fourm but everyones project are different in some way usually just different MCU. But shouldn't some things work exactly on every MCU!?
Well, to get to the point. I have a simple project with some flashing leds and I just can't get i working. I will post it a little bit later. First I would like to ask where can I read about the Setup_counter? I have looked in the Help and in the Manual for the compiler but it makes no sense to me. What does the RTCC_INTERNAL mean? What it's abbreviate for(maby it isn't but usually the hole word makes more sense). And I don't know when to use it and when I don't need it?
In some examples it's used and in some it's not, please someone?
And now to the code.
#include <16LF84A.h>
#fuses XT, NOWDT, PUT, NOPROTECT
#define DIODE1 PIN_B1
#define DIODE2 PIN_B2
#define ONOFF PIN_B4
//setup_counters (RTCC_INTERNAL, RTCC_DIV_1);
while(INPUT(ONOFF))
output_high(DIODE1);
output_low(DIODE1);
output_high(DIODE2);
The problem is that the DIODE1 dosen't flash. DIODE1 turns on but now flashing and if you change the input the DIODE2 goes on.
I would really appreciate an explanation of this.
PostPosted: Thu Dec 08, 2005 4:07 pm     Reply with quote
My suggestion is to start with a very simple program, like this,
where you just try to flash the LED:
   output_low(DIODE1);
Do you have a series resistor between the LED and the PIC ?
husq
PostPosted: Fri Dec 09, 2005 1:17 pm     Reply with quote
Thanks,
Well I tryied the program one more time and it turned out that it wasn't the program, it was my crystal that was kind of messing with me. So I'm working on a little special thing for that. But anyway I would still like to know about the other stuff, anyone?
About when to use the Setup_counter and what the RTCC stands for??
Greatful for any suggestions, and if anyone could recommend some books or papers to read for us newbies?
PostPosted: Fri Dec 09, 2005 1:58 pm     Reply with quote
RTCC stands for "Real Time Clock Calendar", but that name is obsolete. It's now called Timer0 in all Microchip documents.
