USART on 16f876
Max Lazarus
USART on 16f876
PostPosted: Tue Dec 06, 2005 7:57 pm     Reply with quote
All I'm trying to do is get USART-received data to be output on the SPI. This code should display the contents of RCREG and the RCSTA register.
RCREG always equals zero, but the receive pin is obviously working, as when I use getch()s in the code I can use RS232 output from a computer and keyboard to trigger events. I am very frustrated with this, and have no clue why it is not working properly.
Here is the code, minus obvious #defines.
#if defined(__PCM__)
#include <16f876.h>
#device ICD=TRUE
#fuses HS,NOWDT,NOPROTECT
#use delay(clock=4951200)
#use RS232(PARITY=N, BAUD=9600, BITS=8, XMIT=PIN_C6, RCV=PIN_C7)
#include <stdlib.h>
main() {
*setup, serial;
setup_spi(SPI_MASTER | SPI_CLK_DIV_64 | SPI_L_TO_H);
serial = 0;
setup = TRISC;
*setup = 0x80;
output_high(PIN_B2);
output_low(PIN_B1);
serial = 0;
setup = RCSTA;
*setup = 0x90;
setup = RCSTA;
serial = *setup;
spi_write(serial);
output_high(PIN_B0);
delay_ms(1);
output_low(PIN_B0);
delay_ms(1);
*setup = RCSTA;
*setup = 0x80;
*setup = 0x90;
getch();
setup = RCREG;
serial = *setup;
spi_write(serial);
delay_ms(1);
output_low(PIN_B0);
delay_ms(1);
setup = RCSTA;
*setup = 0x80;
*setup = 0x90;
Max Lazarus
Re: USART on 16f876
PostPosted: Tue Dec 06, 2005 7:59 pm     Reply with quote
Max Lazarus wrote:
*setup, serial;
Oops, this is actually
int *setup, serial;
Thanks.
PostPosted: Tue Dec 06, 2005 9:22 pm     Reply with quote
Then keep everything as simple as possible. Try the following program
as a starting point. Also notice the NOLVP in the #fuses and the ERRORS
in the #use rs232(). Those are essential.
#include <16F876.H>
main(void)
char c;
   c = getc();  // Wait for a char from the UART
   spi_write(c);   // Then transmit it by SPI
